I have recently bought a 99 TDI New Beetle. Had to have the head replaced due to water pump failure. Had work done at a VW dealership. But my problem is that after driving the car for a couple of hours it looses power and continues to loose power until I stop and turn the car off, wait a minute or two and the start again. Then it runs fine. Anyone have any problems like this? Check engine light did come on after the fourth or fifth time this happened. Took it to dealership and code showed turbo boost pressure control(P1550). Dealership said turbo was bad and not boosting. Checked turbo myself, no broken fins or slack in bearings, best I could tell. Also installed boost gauge and it shows to have around 20 lbs. of boost. What kind of boos should the car have? Also the car does not get the fuel mileage it was claimed to get could this be linked to my problem? Thanks for any help.
