blizzard60
Do you actually have have the brown/red wire going to pin 22 of the green connector for the cluster? That should activate the hood. If you have it, but the cluster isn't recognizing it, it is either because the IMMO3 clusters get the door reading over CAN which your car won't do and this is confusing it, OR, you have a wiring issue with the hood contact switch F266. Check continuity with the switch and the wire going to the cluster...
