meisterleipz
A friend's automatic tdi is stuck in 3rd gear and is in limp mode. 17965 code is thrown. When you turn off and cycle the ignition limp mode disappears and the transmission will shift through the gears perfectly. but when you rev over 3000 rpm's limp mode comes back and tranny stays in 3rd.
Does limp mode for an automatic cause the tranny to stay in 3rd gear?
There are no tranny related codes thrown.
