Wolfdie
- Joined
- Sep 24, 2017
- Location
- PA
- TDI
- 2001 Jetta 1.8t Wolfsburg, 2002 Golf 2.0 GLS, 2006 Jetta TDI DSR, 2016 Jetta 1.8t TSI Sport
Ok here is my problem. I just did a motor swap cause the other motor was seized.
Now the car wont even start everything else has power. I tested all the wires that I could. Cleaned grounds ect. After lots of failed tries I narrowed it down to the J519 Vehicle Electrical System control module not sending power to J682 433 Relay. I tested the relay its self put 12v to it and it worked. I also Plugged the relay back in with the cap off and pushed the contacts together and it started cranking the starter. I also tested the wire coming from the J527 Steering column electronics control module and it lit up my test light. This issue has me pulling my hair out especially when I have a dead line to have it into the shop for rust and corrosion in a few days . Any help on this would be very much appreciated and I would be very grateful
