Wierd one, Master Cylinder
Canuck378
Canada
Jetta 2006
Evening,
I have a strange one i'm hoping someone might have insight on. I swapped my clutch and installed a new master cylinder.
Ended up having alot of issues trying to bleed the clutch, once we sorted that out mostly, it still wouldn't shift smoothly. Eventually we swapped the slave cylinder as well with no additional success.
Now i'm on my 2nd slave cylinder, and noticed when looking at old receipts that I put in a Master cylinder that was for a duo mass fly wheel, not the solid one which I should have done.
Does anyone know if this is likely my issue, should I go ahead and purchase a more compatible master cylinder?
Any help would be appreciated,
Thanks!
-Paul
