I promised to show some pictures of my cyclonic CCV system. It is almost the same as Josh's, but I have not added a drain to the inter cooler. I also still need to add some hose clamps to my hoses. I found out the hard way that the old CCV grommet is brittle and can snap off. I was driving my car when all of the sudden I could smell a pretty rank smell. I pulled over to see oil all over my engine. I bought a new grommet and all has been well.
I plan to make a mount so that it will bolt to the air cleaner housing. For now it is just installed with zip ties. Once I get the mount made I should be able to get my engine cover back on. The hoses sit up too high and rub on the cover.
You can still see the mess I made of my engine when the grommet let loose.
Here you can see the catch can I am using. It is a baby food jar, the larger size. It is just resting there in place. Real easy to get to as you can see I removed in it for the next picture.
And here is how much oil I have accumulated over the last 5000 miles or so. Seems like quite a bit to me, but I am not sure how much it really is.
I have yet to remove my intercooler and intake hoses to see how clean they are. I am assuming this is helping, but time will tell.
