copilot
The Facts.
Yesterday while I was driving I experienced some power loss or transmission slipping accompanied by an increase in noise from the engine. I pulled into a parking lot and checked the things I could. The oil was at a normal level and has been changed at the proper intervals. Nothing was leaking and there was nothing hanging from the underside of the car. I could hear the turbo spinning up. I was less than two minutes from the closest dealership so I dropped it off last night. This morning I talked to the service manager who told me the injection pump is the cause of the noise and power loss, but that he does not believe my timing belt has ever been changed. My car is a 2001 Jetta TDI with an automatic Trans and has approx 68k miles on it. I purchased it Certified Pre Owned at 42k with the balance of the original warranty and an extended warranty.
The Fuzzy.
The service manager says that the timing belt should have been changed at 40k. I'm not sure if it's 40k or 60k.
The Questions.
I was hoping to keep my TDI well past 200k, will this situation drastically shorten the life of my car?
If the timing belt was never changed, does it mean I was sold a car that didn't have the proper maintenance completed on it?
Should I keep this car once the repair has been completed or should I start shopping for something that I can be sure has had the proper maintenance done at the proper times.
And finally, pending the outcome of the repairs and the clarification of the maintenance records.
Should I get a lawyer?
Any comments, answers or advice from past experiences would be appreciated. Help me out TDIclubbers!!
The Fuzzy.
The Questions.
