mandrake slink
I just did the Luk Clutch Kit on mine this fall. A lot of the same symptoms that were slowly worsening. Get the 4 inch triple square bits from Amazon. Heads up, when getting the old clutch off, it may be farther gone than you're aware of with other **** also stuck in the way. CV axle hex bolts were stripped on mine and w/o lock plates. Clutch pressure plate was seized off-center and you couldn't access the holes for the 12-point bits without grindering the fingers off. I recommend judicious use of the angle or die grinder as necessary.
