Hello, I have a 2003 Jetta TDI Wagon, I have been having a problem with a rough idle lately, but it comes and goes. Some days it idles and runs fine, other days it idles rough and then comes out of it and then it returns later on.
Last week I had fault codes stating that the Quantity Adjuster - Upper limit reached (intermittent) , also had fault code QA- lower limit reached -intermittent (only one time so far).
The IQ had a reading of 1.8 or so, and I adapted it to 3.5. It didn't fix the problem.
Today while idling rough, the IQ was bouncing all over from 0.00 to 3.5 or so.
I can many times shut the engine off, restart, and all is fine (sometimes for a while), other times not.
Today I have the QA upper limit reached fault code- intermittent, along with a new one: 17762 Modulating piston movement sensor (G149) - intermittent.
I am not sure the Hammer Mod is what will correct this intermittent problem or not.
Please help me diagnose this problem!
Thank you.
Jeff
PS: all readings, etc. were done at operating temp.
Thank you.
Jeff
