Old July 11th, 2019, 07:06   #16
eddieleephd
Fuel Economy: 38mix / 47@70-75
Try looking at the pressure when the engine is off. Should be about 14.7 psi.
It's difficult to know what the reading should be without a boost gauge installed on the vehicle.
'02 1.8t Jetta Wagon Alh w/5spd swap, SB 21#SM DD, bew lift pump, 11mm IP, VNT17, Malone stage4 tune, 2.5"cat back st. pipe,Vr6 brakes, 2" lift, Panzer, Bilstein HD, Bosio DLC 1019's PD_fuel_delivery TDI Search Plug release tool Howto terminal release tools VW/Audi
eddieleephd is offline   Reply With Quote
Old July 11th, 2019, 08:29   #17
Stephen417
Would the map sensor be affected by temp? Right now in the morning I leave for work around 4:30 and itís cool enough where the thing feels almost normal, get out and itís 80 and the car is a turd
Stephen417 is offline   Reply With Quote
Old July 11th, 2019, 09:11   #18
eddieleephd
Hmm, that might be the fuel temperature sensor in the IP.
MAP shouldn't be affected by temperature, however, the MAF and fuel temp are
Old July 11th, 2019, 10:59   #19
Stephen417
Is there a way to test it?
Old July 11th, 2019, 11:51   #20
BobnOH
not-a-mechanic
Fuel Economy: 50/45/35
OBDII (like VCDS)
There are several temperature settings, check them cold, then hot. If you see some wack reading, check the wires/connect then replace.
A4 TDI engine measuring blocks/groups
Old July 11th, 2019, 12:01   #21
eddieleephd
What Bob said.
As I have read, and keep reading, the map rarely fails. However, it does fail occasionally. Not sure what the resistance values are. I have a boost gauge and just compare that with log readings.
You said you put in a new MAF, was it OEM? This isn't a place to cheat.
I like having a couple spare parts and a 3 bar is $35 so I have one in the spare parts kit.
Don't seem like I'm being much help here, just giving ideas of where to look.
I would suspect the fuel delivery more than boost, unless your air mass is less than requested, but your pressure is like it is.
Remember I said before to log the MAF readings, that's so you can see if as much air is coming in as expected at those pressures
Old July 11th, 2019, 12:19   #22
BobnOH
not-a-mechanic
Hold out, bump, for someone to look at your graph. There are a few folks who actually know what to look for. I see what looks like the requested bouncing out, but I don't know how to interpret these things.
https://log.malonetuning.com/chart/2...bCsQAAAA%3D%3D
Old July 11th, 2019, 12:51   #23
Stephen417
The MAF that I put in is OEM so I really donít suspect that
Old July 11th, 2019, 12:52   #24
Stephen417
Originally Posted by BobnOH View Post
OBDII (like VCDS)
I believe my coolant sensor is bad, it says 190 F on the dash but itís around 250 F on vcds. Could that be the cause of my problem?
Old July 11th, 2019, 13:03   #25
eddieleephd
If I remember correctly 205 is the top for acceptable temperature and the sensor is the likely culprit.
https://www.myturbodiesel.com/wiki/t...t-mk4-vw-audi/
https://forums.tdiclub.com/showthread.php?t=188334
Old July 11th, 2019, 13:30   #26
Stephen417
I only question if thatís the problem because even when itís cold I still have the issue.
Old July 11th, 2019, 13:38   #27
eddieleephd
Check the temperature when it's cold and again when it's hot. The comparison should tell you. It's definitely a possibility and over of the first things to replace.
Old July 11th, 2019, 19:05   #28
Stephen417
Okay so I swapped it with a good oem one, itís reading correctly in vag com and still no improvement on power
Old July 11th, 2019, 19:09   #29
Stephen417
What Bob said.
When I went to look at the air mass specified vs actual... specified stayed at 850
Old July 11th, 2019, 22:55   #30
Nevada_TDI
IIRC, there should not be that much variance in the two temperature readings; If the factory temp sensor is still the stock one, yup, it should go. I don't remember if the "good one" is green or black in color. The MAP sensors do not often go bad, but they will go bad now-and-again. The temp reading on the dash is mostly an idiot light for people that don't understand how the temperature in a diesel will fluctuate. The other one reading significantly higher is the one the ECU sees and may be part of your problem. As was mentioned the fuel temp sensor in the top of the IP has a lot to do with retarding the timing when hot also killing power...
I came to this website over ten years ago, and could not be happier from the knowledge and insight the members here always offer. I am sharper now on my TDI than I was then, but I still have a lot to learn.
New nozzles are likely in your future, but until you get this problem solved, I would not do any modifications to the engine.
_______________
2001 Jetta GL TDI, Tinted, Vented, No Kitty, EGR-ectomy, TDTuning, HIFLO .216's, TurboLabAmerica Hybrid 15-17/56, VCDS Hex+CAN, S-B Daily Driver 2 Clutch, DG Short Shifter, Frostheater, Baldwin Fuel Filter, Koni Orange, New Paint. Previous Diesel: 1983 Rabbit Diesel
boost issue weaverracing VW MKIII-A3/B4 TDIs 1 April 11th, 2014 13:06
HELP! 99.5 jetta alh boost problems, as well as unknown noise Alexanderp VW MKIV-A4 TDIs (VE and PD) 6 November 8th, 2011 12:28
Boost issue, please help an60an TDI 101 8 December 9th, 2010 23:58
Starter gone bad / unknown issue lilredjetdiwagon VW MKVI-A6 Golf family including Jetta SportWagen (~ 2010-2014) 10 October 17th, 2010 15:31
Boost issue Zacho TDI 101 12 July 11th, 2008 18:58
Page generated in 0.16574 seconds with 13 queries
[Output: 128.80 Kb. compressed to 108.06 Kb. by saving 20.74 Kb. (16.10%)]
