Old July 11th, 2019, 18:09   #1
13tanner
TDI(s): 06 Jetta tdi
Default Tdi Brm lots no throttle response and ticking noise
Hey everyone, I'm new to the forum and am already in need of help!
I picked up an 06 Tdi jetta for a price i couldn't refuse but it is definitely a project! When i got it, the engine would start and run for one second and then die. That turned out to be a broken ground wire under the dash on the pillar that i got lucky and noticed. I don't know much on the background of it but it seems from old parts in the trunk and what i've inspected, there has been a lot of recent work. The camshaft and lifters have been replaced. Turbo compressor wheel and seals, head gasket, timing belt and water pump have all been done recently.
Now that i've found the broken ground it will start and run but really only idle. The idle will only go up about 200rpm if i use the throttle.
Ive checked the ASV (i think its opening and closing correctly) as well as the egr valve (looked very clean). The egr cooler is definitely leaking but would that cause this whole issue? I don't have a vag-com unfortunately but my cheap code reader is only showing a code for #4 glow plug circuit.
Sorry to jump around so much i'm just trying to get all of the info i have out there. If anyone has any ideas to what could be causing this, i am all ears!
https://www.youtube.com/watch?v=iDK9GoiDRm4
It seems to crank longer than it should also. You can hear when i press the throttle in this video, the egr leak gets much louder and rpm's raise by a couple hundred but that's it. You can also hear the ticking that i haven't found the cause of yet either so if anyone has heard similar or has any ideas what that could be would be great! I pulled the valve cover and the cam lobes look brand new with no wear as well as lifters. Also pulled the oil pan today and felt all the main and rod bearings for play. there was no play and not a spec of metal in the oil.
13tanner is offline   Reply With Quote
Old July 11th, 2019, 18:17   #2
banshee365
TDI(s): 06 Jetta
I do NOT like the sound of that ticking/knocking noise.
banshee365 is offline   Reply With Quote
Old July 11th, 2019, 18:34   #3
13tanner
yeah i really don't either.. i do think it was kind of amplified because it was in my closed garage. It didn't sound as bad when it was outside idling https://www.youtube.com/watch?v=t2pG_9duRek
Old July 11th, 2019, 21:32   #4
Carlos_TJ
Seems you have several issues at the same time
Be patient and fix them (including whatever the previous owner mis diagnosed or mis installed)
1.- long time crank
A) torsion adjustment out of spec
B) clogged fuel filter
C) broken cam sensor (iirc brm runs with the crank signal only? Correct me if i am wrong)
D) ticking noise - collapsed cam lifter
E) unresponsive throtle - possible erratic pedal signal
You must scan car with vagcom. Generic obd2 is no good.
Find someone on your area with vcds. Many folks will help a brother out for a beer
Post your scan and lets take it from there
Carlos_TJ is offline   Reply With Quote
BRM makes a faint ticking noise? buyingconstant7 VW MKV-A5 Golf/Jettas 3 May 16th, 2016 09:29
Mk5 BRM ticking noise from glovebox? buyingconstant7 TDI 101 0 December 3rd, 2015 22:16
Jetta tdi low throttle response dvdyzfr6 TDI Power Enhancements 5 May 5th, 2014 19:55
Help! I Got no Code, No throttle response (intermittant) Jetta 2006 TDI Radical VW MKV-A5 Golf/Jettas 5 February 9th, 2013 10:08
whats available cheap that helps throttle response 2006 tdi falconslayer TDI Power Enhancements 9 December 30th, 2007 17:31
Page generated in 0.15862 seconds with 13 queries
[Output: 63.64 Kb. compressed to 57.30 Kb. by saving 6.34 Kb. (9.96%)]
