Go Back   TDIClub Forums > TDI Model Specific Discussions Areas > Audi SUVs (Q7 & Q5) and other V6 TDIs
Audi SUVs (Q7 & Q5) and other V6 TDIs Discussions area for Audi Q7 and Q5 TDI (2009+ in Canada & the US) as well as others with the V6 TDI such as the A6, A7 and A8 sedans.
Old July 11th, 2019, 10:43   #1
andreigbs
TDI(s): N/A
Question 2010 Q7s with the fix?
We are looking at possibly trading in our '14 Jetta TDI for a bigger AWD diesel, and the Q7s and T-regs come to mind.
I found a couple 2010 models in the area that have had "the fix" done late last year; one with over 160K miles and around $9k, and one with 94K miles for around $13k. The more expensive one also has HIDs and a few other goodies.
The Carfax reports are generally clean (no accidents, etc) but the lower priced one includes the "engine removed" as part of a repair, which naturally concerns me. I've spent time here reading that almost anything to do with the timing chain probably requires either the whole front end to come off or the engine to come out. This may be what happened here as well.
I'm looking for advice from our resident specialists, such as @Oilhammer, and other experienced Q7 owners regarding what I should be on the lookout for. The dealer has five Q7s on hand but I'm only looking at these two specifically because trading the Jetta wouldn't put me upside down (ideally).
Should I be worried about timing chain issues? Suspension components near end of life? Transmission maintenance that may be overlooked? Other things that any of you have noticed that you wished you had noticed before you picked up your Q7?
I've had a couple Audis in my day, plenty of VWs, and I know generally what to expect. But these tanks are big beasts and I hadn't been considering them in the past, so I neglected to learn much about them.
Thanks, all, in advance.
BMW X3d // 55xxx miles // 35 MPG & GLK250 // 121xxx miles // 32 MPG
Jetta TDI // 49xxx miles // 39 MPG - sold
Golf TDI // 45xxx miles // 38 MPG - buyback'ed
Bora TDI // 146xxx miles // 42 MPG - sold
Jetta TDI // 317xxx miles // 44 MPG - sold
andreigbs is offline   Reply With Quote
Old July 12th, 2019, 05:36   #2
andreigbs
TDI(s): N/A
No one has anything to offer?
Old July 12th, 2019, 08:19   #3
Radman
Try ClubTouareg for more activity on the 3.0TDI
My thoughts is a 2010 is getting old and has the 6 speed transmission so not very economical. Look for 2011+ for the 8 speed tranny and 2013+ for the higher HP engine.
2014 Audi A6 TDI, Unitronic Tuned
2014 Touareg TDI, Unitronic Tuned
Radman is offline   Reply With Quote
Old July 12th, 2019, 09:22   #4
andreigbs
TDI(s): N/A
Thanks Rad, that's what I've been doing. I just thought to ask here first, after reading all the threads available in this subsection.
Trouble is that the newer models the dealer has on hand are priced much higher, so would 2 extra gears be worth, say, $6K more? I'd like newer and with less miles obviously, but I'd be happy with anything under 100K. Plus there's the extended warranty which is good. My Jetta has a 6-spd which is sufficient, my GLK250 has 7 forward gears which is nice.
I'm just trying to decide how best to trade up without trading upside down. Thank you for your thoughts, much appreciated.
Old July 12th, 2019, 12:44   #5
Radman
Check on Fuelly.com and browse different years. It should give a good idea of MPG averages. Check the trim levels and options. That alone can have a significant impact on price.
I had a Jeep Grand Cherokee Diesel with 6 speed and it was terrible vs the Touareg by around 10MPG.
2010 Jetta door latch fix. soot1 VW MKV-A5 Golf/Jettas 27 July 20th, 2020 17:54
2010 JSW post-fix osxuser Dieselgate - VW Group Emission Scandal 3 March 5th, 2019 12:54
2010 Jetta getting the 'fix' to now being turned in. rca3rd Dieselgate - VW Group Emission Scandal 15 September 25th, 2017 02:22
Need Advice: fix or sell 2010 Jetta with possible head gasket probs bbalenger TDI 101 7 June 9th, 2015 16:23
2010 overhead console rattle fix rjdio VW MKV-A5 Golf/Jettas 6 January 6th, 2012 12:54
Page generated in 0.08791 seconds with 13 queries
[Output: 69.94 Kb. compressed to 61.98 Kb. by saving 7.96 Kb. (11.38%)]
