I used BMW type hydraulic puck mounts.
Nice! My steering wheel has a little buzz at an idle but smiths out when you give it a little throttle. I’m supprised at how smooth it feels when I put my hand on the valve cover. The steering wheel actually vibrates more.Not bad,it gives a little kick when shutting it off but pretty good when drivin'.
the best ! "fully adjustable"
I used these for years with my Vanagon conversions. There are two types of these mounts - Black and Green - with the green being slightly stiffer. I have used both and really found no difference.I like the look of that Fox mount, so I ordered one. I’ll be installing it as the rear mount in my AAZ Rabbit pick up, and if it works out, another for the project car.
I figure that air gap would be better than the solid block that the stock mount is. I can stuff some rubber sheeting in, if it needs to be firmed up. Fingers crossed....
-Todd
