Got Haggis?
10WD40 ok? Wasn't sure if diesels needed a special type or anything
... from everything I've heard on this list, you may have BEEN getting WD-40, for all the dealerships seem to know about TDIs.LOL nice typo on my part.
anyway i had been just having the shop do the oil changes whenever i take it in for the 10k service intervals, but want to start doing it myself.
Oh.
the mfr is going to suggest a 5w40 and there are plenty of choices. 5W40 will always be synthetic. (Removed image)
there is no shortage of excellent oil choices for pre-2004 TDis!
Yes, all Mobil 1s are "fully synthetic." As to CI rating, the can clearly does not list the VW 505 spec. It does say "Outstanding protection for gasoline, diesel and turbocharged car engines." and "Exceeds API Service SJ, SH /CF." API CF is the API designation for diesel engines, I am sure. My reading of the VW manual is that any one listed spec is sufficient.Is that oil full synthetic and CI rated?
Your mileage improved because you switched to a lower-viscosity motor oil. It would improve even more if you switched to a straight 10-weight or 5-weight.I started putting in Mobil 1 Truck & SUV when it came out... About six months ago, I went for an oil change but forgot to bring the oil. I said they could use the Mobil 1 that they stocked. That was "Mobil 1 Extreme Formula 0W-30." Funny thing, right after the oil change, my mileage went up about 2 mpg.
Actually, I think you are. CF is not the same as CF-4 (or CG-4, CH-4, CI-4 or the new CI-4 Plus).I went to the Mobil 1 web site for some assurance.
www.mobil1.com has a box for oil selection. I clicked it, and no matter how I work it, only one oil comes up for my "choice"-- that's Mobil 1 Truck & SUV. Undaunted, I went to my car's manual. As he said, the car manual says I must have one or more of the listed specs. It recommends 5W-40 but says that 5W-30 is okay if 5W-40 is unavailable. Well, the oil is SAE 30 hot, and the bottle has one of the required specs: API SJ/CF. Since there is no 4 suffix, I assume they mean for it to be included. Now, the complicated parts--
The can says it meets VW performance requirements AND the VW dealer seems to agree since that is the only oil he provides (besides Castrol?--not sure).
So, let's have it. Am I making a big mistake?
FYI, I just saw that Mobil 1 0W-40 lists the VW 505.00 spec on the bottle. This must be new.
Delvac 1 meets the CI-4+ specification, Mobil 1 T&S only CI-4. Any thoughts on whether Delvac 1 has anything extra that we ought to be interested in? Or, at $20 for five quarts, T&S is such a good deal that we don't need to inquire whether Delvac 1 might be just a wee bit better?T&SUV has the highest Diesel specific rating which is specific for EGR equipped diesels namely CI-4. Any other rating is considered obsolete and a lesser specification unless its CI-4 or CI-4+.
...the 0-40 may WORK in your car...but it was not DESIGNED for a Diesel motor....
Facts duely noted...the 0-40 may WORK in your car...but it was not DESIGNED for a Diesel motor....
ofhs, that's not quite accurate. The 0W- 40 oil is certified against 505.00 (diesel-only standard) and certified against ACEA B3 and B4 - - these are exclusively diesel standards
A few of us had run the 0W40 oil. I noticed immediate oil consumption when using it, but that was my only concern. In theory, it would be an excellent solution for our brothers in the GWN during those frigid winter months and it's fully certified for any VW diesel except the PD motors.
API CF and CF-4 are different, non-interchangeable ratings.www.mobil1.com has a box for oil selection. I clicked it, and no matter how I work it, only one oil comes up for my "choice"-- that's Mobil 1 Truck & SUV. Undaunted, I went to my car's manual. As he said, the car manual says I must have one or more of the listed specs. It recommends 5W-40 but says that 5W-30 is okay if 5W-40 is unavailable. Well, the oil is SAE 30 hot, and the bottle has one of the required specs: API SJ/CF. Since there is no 4 suffix, I assume they mean for it to be included.
Valvoline Max Life Synthetic 5W-30 does have the VW 505.00 rating. The VW 505.00 (and ACEA A3, B3, and B4) rating specifies HTHS > 3.5, which can be met by *W-30 oils on the thick end of SAE 30. Most *W-30 oils sold in the US (including Mobil 1 oils) are on the thin end of SAE 30, so they do not meet HTHS > 3.5 for these VW and ACEA ratings (there are the ACEA A1, A5, B1, B5 ratings for 2.9 < HTHS < 3.5 oils).The issues with any oil with a w30 rating is increased wear in the cam and lifter regions of your motor.
Review the 505.00 spec it lists only 0w40, 5w40 and 10w40 viscosities.
