Iluv, it was 6 months...O'Rattler, X2.
There is a very good mechanic, in Stafford, VA, as I said before. Depending where in VA you live, probably closer. Last I knew, Oliver lived in Baltimore. I would trust either mechanic with my car.
An engine that is driven below recommended rpm's will cause sooting, but then, if I were the mechanic seeing that, I'd probably have driven the car 'for effect', rather than tear down a turbo. Soot can be burnt out by driving correctly. As example, one of the other local experts from Missouri (OilHammer)will get a car that is running poorly and his 'fix' is to drive the vehicle 40 miles back and forth from his home to work for a week. The the customer gets the car back, they ask "What did you do?!?" His response is, "I drove it." Actually, drove it correctly...I believe the real need for your turbo tear-down was at best, questionable.
Injectors that are not running properly will also cause sooting and show poor fuel economy. That usually can be determined by checking a few blocks in the VAG-COM software.
Last thing, Howard, it's not 'belts', it's a timing belt KIT. Changing out only the timing belt is another recipe for disaster. 3 Rollers, water pump, Tensioner, seals, timing belt and serpentine belt; that is the kit...and someone with the proper tools to do it right.
Questions? I am available and have the reputation to back what I am talking about.
