Mine does exactly that on calculated soot but the measured soot seems way off.Might be because it isn't really matched to our engine types. Mine seems to be correct though as it starts a regen at about 23.5 and stops around 4.5. Just watched one a few days ago. The developer is not from the US so getting settings for our cars is a hit or miss with what is already available in the app.
Bosch does not expect measured soot reading to be accurate. It is determined by the d/p sensor.Mine does exactly that on calculated soot but the measured soot seems way off.
So that would pretty much make the measured soot reading a useless number?Bosch does not expect measured soot reading to be accurate. It is determined by the d/p sensor.
That's why calculated soot determines when you regen. The internal model calculations are considered to be more accurate.
