Torque!
Yesterday I resurrected my gelled TDI.
I recharged the battery (Do I need to replace it after it got run down? Is a recharge adequate?)
While the battery was charging I added more fuel I had warmed up inside the house and added some additive.
In the engine bay I replaced the fuel filter and re-installed the engine cover. (I noted that the engine cover does a good job of shielding the injector pump from wind. It may make a more significant difference in cold weather than I previously thought.
After all this a few cranks and I'm back in business.
Now I am paranoid.
I logged my commute with the VAG monitoring fuel temp (Group 7?) and it steadily rose the whole trip. The outside temp was 38F. Fuel temp rose from 20.7c to 32c
I still have questions about the automatics fuel cooler. Does anyone else question why a device that cools fuel in the return line a good thing?
I imagine that warm fuel returning to the tank and filter keeps the system warm. What good is a 4" x 10" radiator on the return line under the front passenger seat. I am resisting an urge to cover this thing or bypass it in winter. Does anyone have any insight?
Also has anyone confirmed that new fuel senders have larger check valves than the original ones?
When I couldn't start the car the problem was definitely between the tank and the fuel filter.
BTW I rented a GEO Metro while I was down and feared for my life in this thing. What a drastic difference in solid feel and quality between these cars.
Now I am paranoid.
