gjm123
- Joined
- Jul 9, 2008
- Location
- South of Auckland, NZ
- TDI
- (ex-1997 Audi A4 TDi Quattro Avant); now BMW E46 320d Touring
Has anyone any advice for this?
Looks like the pinion bearing on my B5 is less than happy - I have a road speed related whine/grumble from the gearbox or front diff. I believe it to be on the output side of the transmission; clutch in or out, in gear or out, number of engine revs, makes no difference. The sound is present while the car is moving and doesn't change or go away when turning a corner. Oil level is fine. The car has done nearly 155k miles.
The odd thing is that this noise first appeared about 9 months ago. At the time we drained the gearbox oil and refilled using Fuchs 75W90. Audi claimed the 'box is 'sealed for life' but the thin dark liquid that we drained from it would suggest otherwise. The noise almost immediately became worse, but then went away completely.
I suppose it might go away again, but we're off to France in a couple of weeks time and I don't fancy trying to explain a duff gearbox to a Frenchman in his rural garage! Better safe than sorry.
I've been quoted £300+VAT to have the new bearing fitted - £60 for the bearing, £40 for the seals and gaskets, and £200 for the labour. It'd be another £200+VAT to have the trans specialist remove and refit the 'box.
I have the option of a used box from an 80k mile car for £140+shipping (about another £40) but the concern is I could spend that and find the replacement 'box needs work too. "It was fine when it came out of the car" is all very well, but the seller (a breaker) won't offer any sort of guarantee of integrity.
I have a Haynes manual that details gearbox R&R on a front wheel drive car, but nothing giving any info for the quattro.
The question of 'is it worth it?' has been raised, but I recently replaced the front suspension arms and rear locating arms for the MoT, and have replaced all discs and pads in the last year. It's a great car, and I'd rather spend some money fixing it and know where I stand than buy another car and possibly find more problems.
Finally, does anyone have an idea of the weight of the quattro gearbox?
Any hints, tips or advice will be very welcome! And if anyone is in the Norwich area of England, please do get in touch!
TIA.
TIA.
