got_vdub
My friend has taken on the job of rebuilding my 99.5 1.9L after blowing some piston rings and spinning some rod bearings. The engine was completely hot tanked and had the cylinders rehoned along with Races Wares head studs new timing belt, new oil/water pump. All new gaskets and seals, filters, along with a Upsolute Stage III kit and TDiRacing.com P520 nozzles. All the machine work was done at the best shop in the area, everything is set to stock, and my friend is more than capable to handle that task but he has ran into 1 problem. . .
The car won't start, he doesnt think he is priming the fuel pump is seems that there isnt enough fuel getting into the cylinders, he first did the test were he "cracks" the injectors to see if they are spraying, and then he manually pumped fuel to the front of the car is get it going. Does anyone have any ideas or any tips or advice to get my baby running again? Anything would be greatly appreciated
You can see all the work being done here at this site. . . http://forum.benbuilt4u.com/showthread.php?t=553
