OP needs to use a proper scan tool to get all the info.
The preglow lamp should come on when you turn the key on ALWAYS, regardless of ambient or coolant temps. If there is no preglow required, it will go back out almost immediately.
Despite the myth that persists here, despite my continued efforts to thwart its propagation, the glow system on your car
works all year round, even in the summer. There are TWO distinct strategies at work here:
preglow, which aids in cold starting, and
afterglow, which aids in emissions reduction after the engine is started.
Preglow occurs starting around 50F coolant temps, but can actually vary depending on which engine/software by input from other sources like the MAP, as high altitude can create a more aggressive strategy.
Afterglow will happen at higher coolant temps. Even on a 70F "cold" start, afterglow can occur. And it works below 2500 RPMs and has a maximum time period, regardless of RPM or coolant temp, of around (going by memory here) 4 minutes. On the 2-channel ALH cars (1998 through the first month of 2002), you can HEAR the glow relay clicking on and off inside the car as the engine sweeps past 2500 RPM. The later 2002-2003 ALHs, as well as all PDs and CRs, have their relays outside either next to the ECU or in the engine compartment, and those are duty cycled... so you won't hear them. But the basic idea of pre- and after-glow still applies.
In any event, on any TDI (with the exception of some 1996 Passats with OBD-D), the glow system is monitored by the ECU all the time. If there is a fault in the system, the ECU will know it, and the MIL will come on.
It is possible to have a DTC for a glow plug circuit (either 2 or 4 (or 6 or 10
) whichever your car has, but it is also possible to have a DTC relating to the control unit (relay) itself. LOTS of generic scan tools will not show these relay-related DTCs. While it is not very common for the ALH's relay to fail, it can happen. This could cause the preglow lamp to not come on when it should.
If the MIL does not come on when you turn the key on, and the engine cranks but will not start, you may have a failing relay 109, which powers up the ECU. This is pretty common... moreso on older cars, but even the newer ones are starting to age and mile up and having them randomly act up.
