foodking
This is a 2006 Jetta TDI DSG
So here's the story,
From a cold start, engine starts, ~1 second later it stalls. Crank from anywhere from 10seconds to several minutes (longer it sat, longer i have to crank) and it starts back up and runs like normal. This started roughly around March. Brought the car into a shop from the trusted TDI list from these forms. Came back saying no codes so they checked the fuel pump. Fuel pump wasn't priming. Got that replaced. Problem still happened every now and then, usually if the car sat unused over a weekend or so. They checked all the fuel lines for leaks and couldn't find anything. Still no codes. In late Apr/early May, took the car into the dealership. No error codes, said the fuel filter was clogged so they:
replaced fuel filter
cleaned injectors
purged fuel line
Engine still stalled. came back 2 weeks later, no codes couldn't reproduce problem, told me to come back with a video.
Fast forward several months, engine still stalls every so often and then it started happening consistently. Basically, if the car sat for ~8.5hrs or more, it would stall. Brought it back to the dealership, no codes. Said the fuel pump needs to be replaced again. Had the shop replace it under warranty, brought it back to the dealership 2 weeks later. They came back with a P2015 code and wanted to replace the throttle body. That confused me. When I searched about it, it usually comes with a check engine light. Co-worker who fixes and sells cars checked for codes, no codes. I purchased a cable from ross-tech and no throttle body code. But it did have a couple things and was hoping someone could tell me if they're related.
Chassis Type: 1K (1K0)
Scan: 01 02 03 08 09 0F 15 16 17 19 1C 25 36 42 44 46 52 56 62 72
7D
VIN: Mileage: 267160km-166005miles
00-Steering Angle Sensor -- Status: OK 0000
01-Engine -- Status: OK 0000
02-Auto Trans -- Status: OK 0000
03-ABS Brakes -- Status: OK 0000
08-Auto HVAC -- Status: OK 0000
09-Cent. Elect. -- Status: OK 0000
0F-Digital Radio -- Status: Malfunction 0010
15-Airbags -- Status: OK 0000
16-Steering wheel -- Status: OK 0000
17-Instruments -- Status: OK 0000
19-CAN Gateway -- Status: OK 0000
1C-Position Sensing -- Status: OK 0000
25-Immobilizer -- Status: OK 0000
36-Seat Mem. Drvr -- Status: OK 0000
42-Door Elect, Driver -- Status: OK 0000
44-Steering Assist -- Status: OK 0000
46-Central Conv. -- Status: OK 0000
52-Door Elect, Pass. -- Status: OK 0000
56-Radio -- Status: Malfunction 0010
62-Door, Rear Left -- Status: OK 0000
72-Door, Rear Right -- Status: OK 0000
7D-Aux. Heat -- Status: Malfunction 0010
Address 01: Engine Labels: 038-906-016-BEW.lbl
Part No SW: 03G 906 016 AC HW: 028 101 223 9
Component: R4 1,9L EDC G000DG 7551
Revision: --H02--- Serial number: VWZ7Z0F3540022
Coding: 0050078
Shop #: WSC 00066 000 00000
VCID: 64C7F682A710F11ED9-8030
No fault code found.
Readiness: 0 0 0 0 0
Address 02: Auto Trans Labels: 02E-927-770.lbl
Part No SW: 02E 300 043 HW: 02E 927 770 AD
Component: GSG DSG 082 1126
Revision: 05508020 Serial number: 00001201051633
Coding: 0000020
Shop #: WSC 44551 111 44551
VCID: 51A92F56C8A274B682-8004
Address 03: ABS Brakes Labels: 1K0-907-379-MK60-F.lbl
Part No SW: 1K0 907 379 AA HW: 1K0 907 379 AA
Component: ESP FRONT MK60 0102
Revision: 00H13001
Coding: 0021122
VCID: 71E98FD668E254B6A2-8024
Address 08: Auto HVAC Labels: 1K0-907-044.lbl
Part No: 1K0 907 044 BE
Component: ClimatronicPQ35 090 0808
Shop #: WSC 00000 000 00000
VCID: 6BD59DBE4ACEBE6698-803E
Address 09: Cent. Elect. Labels: 3C0-937-049-23-H.lbl
Part No SW: 3C0 937 049 E HW: 3C0 937 049 E
Component: Bordnetz-SG H37 1002
Revision: 00H37000 Serial number: 00000000283332
Coding: 14018E234004150000140000001400000028770B5C
Shop #: WSC 09151 444 57467
VCID: 2B555DBE8A4E7E66D8-807E
Subsystem 1 - Part No: 1K1 955 119 C Labels: 1KX-955-119.CLB
Component: Wischer VW350 013 0402
Coding: 00063445
Shop #: WSC 09151
Address 0F: Digital Radio Labels: 8E0-035-593-SIR.lbl
Part No SW: 8E0 035 593 D HW: 8E0 035 593 D
Component: SDAR SIRIUS H03 0060
Revision: 00000000 Serial number: AUZ4Z7F5018942
VCID: 2A5B58BA85B4676E23-807E
1 Fault Found:
02635 - Tuner Not Enabled/Activated
000 - -
Freeze Frame:
Fault Status: 01100000
Fault Priority: 7
Fault Frequency: 1
Reset counter: 64
Mileage: 262628 km
Time Indication: 0
Date: 2000.00.00
Time: 06:40:04
Address 15: Airbags Labels: 1K0-909-605.lbl
Part No SW: 1K0 909 605 P HW: 1K0 909 605 P
Component: 39 AIRBAG VW8R 032 7900
Revision: 03032000 Serial number: 0038FD04C33I
Coding: 0013113
VCID: 397977F67012DCF65A-806C
Subsystem 1 - Part No: 1K0 959 339 E
Component: BF-Gewichtsens. 006 0005
Subsystem 2 - Serial number: 6332MSME0E2E2623E
Subsystem 3 - Serial number: 6342MSME0C6F061FR
Subsystem 4 - Serial number: 6351HSME08730613
Subsystem 5 - Serial number: 6361HSME09295F48K
Subsystem 6 - Serial number: 63727SME09071954
Subsystem 7 - Serial number: 63827SME09214629.
Address 16: Steering wheel Labels: 1K0-953-549-MY8.lbl
Part No SW: 1K0 953 549 AJ HW: 1K0 953 549 AJ
Component: J0527 034 0070
Coding: 0012021
VCID: 7AFBA8FA359417EE13-802E
Subsystem 1 - Part No: XXXXXXXXXXX
Component: E0221 007 0050
Address 17: Instruments Labels: 1K0-920-xxx-17.lbl
Part No: 1K0 920 972 L
Component: KOMBIINSTRUMENT 3HL 4312
Coding: 0023203
Shop #: WSC 09151 067 57207
VCID: 35617BC65C0A3896BE-8060
Address 19: CAN Gateway Labels: 1K0-907-530-V1.clb
Part No SW: 1K0 907 530 F HW: 1K0 907 951
Component: Gateway H10 0120
Revision: H10 Serial number: 28001061081117
Coding: 3F7F0B600F1002
Address 1C: Position Sensing Labels: 1Kx-919-xxx-1C.lbl
Part No SW: 1K5 919 965 A HW: 1K5 919 965 A
Component: Kompass 005 0003
Revision: 00005000 Serial number: 1293324T1WHF01
Coding: 0000003
Address 25: Immobilizer Labels: 1K0-920-xxx-25.clb
Component: IMMO 3HL 4312
Address 36: Seat Mem. Drvr Labels: 3C0-959-760.lbl
Part No SW: 3C0 959 760 B HW: 3C0 959 760 B
Component: Sitzverstellung 0701
Revision: 00003000 Serial number: 00000000000000
VCID: 2C575EA28F40795ED1-8078
Address 42: Door Elect, Driver Labels: 1K0-959-701-MIN2.lbl
Part No: 1K0 959 701 K
Component: Tuer-SG 024 2377
Coding: 0001269
VCID: 36637CCA410C338EB7-8062
Address 44: Steering Assist Labels: 1Kx-909-14x-44.clb
Part No: 1K1 909 144 J
Component: EPS_ZFLS Kl.5 D04 1606
VCID: 326B40DAAD642FAE9B-8066
Address 46: Central Conv. Labels: 1K0-959-433-MAX.clb
Part No SW: 1K0 959 433 AT HW: 1K0 959 433 AT
Component: 01 KSG PQ35 G2 010 0101
Revision: 00010000 Serial number: 00000000000000
Coding: 1B900E880106083F2904058FB0080F0480A540
VCID: 020BD01A5D445F2E4B-8056
Subsystem 1 - Component: Sounder n.mounted
Subsystem 2 - Component: NGS n.mounted
Subsystem 3 - Component: IRUE n.mounted
Address 52: Door Elect, Pass. Labels: 1K0-959-702-MIN2.lbl
Part No: 1K0 959 702 K
Coding: 0001269
VCID: 377D71CE4606CA86AC-8062
Address 56: Radio Labels: 1K0-035-1xx-56.lbl
Part No SW: 1K0 035 180 C HW: 1K0 035 180 C
Component: Radio ZSW 016 0017
Revision: 00016000 Serial number: VWZ5Z7F6013016
Coding: 0040400
VCID: 204FBA92F388AD3E7D-8074
1 Fault Found:
00668 - Supply Voltage Terminal 30
002 - Lower Limit Exceeded - Intermittent
Freeze Frame:
Fault Status: 00100010
Fault Priority: 3
Fault Frequency: 26
Reset counter: 177
Mileage: 263360 km
Time Indication: 0
Date: 2000.00.00
Time: 22:44:59
Address 62: Door, Rear Left Labels: 1K0-959-703-GEN2.lbl
Part No: 1K0 959 703 D
Component: Tuer-SG 021 2434
Coding: 0000144
VCID: 31694FD6A86214B6E2-8064
Address 72: Door, Rear Right Labels: 1K0-959-704-GEN2.lbl
Part No: 1K0 959 704 D
Coding: 0000144
Address 7D: Aux. Heat Labels: 1K0-963-235.lbl
Part No SW: 1K0 963 235 E HW: 1K0 963 235 E
Component: PTC-Element 0404
Revision: 00800000 Serial number:
VCID: 2D5153A6B45A7056C6-8078
1 Fault Found:
00361 - Heater Element for Auxiliary Heater (Z35)
014 - Defective
End-------------------------(Elapsed Time: 02:15)--------------------------
I'm assuming the radio code is the speaker that goes in and out. I don't really care about it. When i searched the Heater Element, it means my heater doesn't work. Turned on the heater this morning, it was plenty hot. So could that mean the glow plugs? Anyone experienced this weird stalling and fixed it?
Couple co-workers suggested getting a vaccum pump and test the fuel lines. They're thinking their might have been a pinhole in the fuel line and replacing the fuel pump overcame that but the hole got worst over time. So that's probably where i'm going next.
cleaned injectors
purged fuel line
7D
Coding: 0050078
Coding: 0000020
Revision: 00H13001
Coding: 0021122
Coding: 00063445
Shop #: WSC 09151
1 Fault Found:
000 - -
Freeze Frame:
Fault Priority: 7
Fault Frequency: 1
Reset counter: 64
Mileage: 262628 km
Time Indication: 0
Date: 2000.00.00
Time: 06:40:04
Coding: 0013113
Coding: 0012021
Coding: 0023203
Coding: 0000003
Coding: 0001269
Coding: 0001269
Coding: 0040400
1 Fault Found:
Freeze Frame:
Fault Priority: 3
Fault Frequency: 26
Reset counter: 177
Mileage: 263360 km
Time Indication: 0
Date: 2000.00.00
Time: 22:44:59
Coding: 0000144
Coding: 0000144
1 Fault Found:
014 - Defective
