I've got two questions regarding a 2000 Golf TDI.
(1)Where is the Main Glow Plug Relay located?
I've looked through my Bentley CD and have not found the location for the main glow plug relay. I've located the coolant heater relays under the hood, but need to access the engine Glow plug relay for diagnostic reasons.
(2)Need suggestions for a cold start problem.
This Golf has had starting problems that originally were traced to a faulty ECT sensor. We replaced the sensor and after a week, the same symptoms are surfacing. The glowplug light comes for only a very short period during a cold start, but no power to the plugs. If we unplug the ECT, the system works fine. We have tested all glow plugs and found them to be OK. I've cleared the DTC's with VAG COM and done an output test which appears to work fine.
Thanks,
Les Burt
[ November 02, 2002, 07:41: Message edited by: B3Syncro ]
Thanks,
Les Burt
