n_spot
Hi, I recently bought an "03 TDI Jetta (sedan) manual, and did quite a bit of work to it prior to even driving it. It has 223,000 miles on it. I replaced the timing belt, water pump, tensioner, etc. and timed with VCDS.
First off, I have always wanted a TDI and it makes sense because I commute 70 miles round trip 5 days a week plus other longer trips. I also have owned to other 2001 gassers. Anyway, my whole purpose for getting this car is to get good mileage (>45).
Things I have done to it
Additionally, I believe that the injector nozzles are original. I ran a can of diesel purge directly through the nozzles to see if cleaning them would help, but it hasnt. I have been considering getting the Bosio DLC520s, for increased mileage anyway. Could it be possible that the original nozzles are worn enough to decrease mileage.
Also, the previous owner said that the fuel filter had been changed in the past year, so I havent chagned mine yet, but I just bought one and plan to change it soon, so that won't be a factor.
I have confirmed that the brakes are not dragging.
If you have any suggestions are response to my questions, any help would be appreciated. Thanks.
- timing belt change
- ventectomy
- oil change with filter
- cleaned EGR and intake manifold
- and many other things that do not pertain to mileage
