MITBeta
- Joined
- Feb 24, 2001
- Location
- Boston's Metro South-West
- TDI
- 2001 Jetta TDI, 2004 Sprinter CDI Passenger (Mid/High), former: 1996 Passat TDI Variant
For those of you joining this story already in progress, here are links to the story as it unfolded:
Biodiesel sludge v1.0:
http://forums.tdiclub.com/NonCGI/ultimatebb.php?ubb=get_topic;f=5;t=005194
Suction strainer help:
http://forums.tdiclub.com/cgi-bin/ultimatebb.cgi?ubb=get_topic&f=5&t=005219&p=
Fuel Temp sensor fault code:
http://forums.tdiclub.com/NonCGI/ultimatebb.php?ubb=get_topic;f=3;t=008764
And now the latest:
I finally got a tool (not the proper one by any stretch, but it worked with only a small amount of bloodshed) to unscrew the large retaining nut that holds the suction strainer/return and the fuel tank level switch in place.
Here's what I found (these pictures may not be suitable for all biodiesel fans
) (descriptions ABOVE respective pictures)
First, the lower contents of the suction strainer assembly:
This is what came out of the top section of the strainer (ie it was floating on the stuff on the bottom:
This is the residue on the bottom of the strainer cup after the sludge was poured off. Notice the rust colored flecks... still as yet unidentified.
The fuel gage sensor/sender... again, notice the milky/chalky residue in the nooks and crannies and the color of the fine residue.
[ September 23, 2002, 15:44: Message edited by: MITBeta ]
And now the latest:
