willbhere4u
I bought this 2000 beetle TDI 5spd 185k cheap because a shop in town replaced the turbo and timing belt and it would not run right when they finished it so i got it cheap. It smokes white nasty unburned diesel fumes enough that people thought my car caught fire!!!
I checked there timing and injection timing and they where correct. I then checked compression it comped out cold at 290-300-325-325 Then I let it get up to temp and I got 200-300-200-300 The longer it runs the more it smokes and harder it is to start.
I pulled the head to check for valve interference damage and found nothing so I pulled the valves out and they are all the same length and straight as an arrow no deformation on the steams. Evan the seal faces looks decent. very minimal play in the valve guides
I checked the piston protrusion height to check for a bent rod and all 4 pistons where between .040in & .042in above the deck height sounds normal to me it has a 2 dot head gasket. The pistons mover ever so slightly in there boars back and forth and side to side is that normal? The cylinder walls are clean no scratches they just looked polished with very minimal barley noticeable cross hatching. And a very slight lip at the top of the cylinder
So either the rings just gave out all of the sudden or the lifters are holding the valves open? It did have some really thick oil in the engine when I got it almost like motor honey nasty sticky stuff. I changed it out for standard Rotella but it made no difference for the smoking.
I am going to hone and replace the rings and rod bearing in the car and replace the lifters and valve seals. And other ideas on what to check?
