Pulls to the right accel, opposite decel
rpm-inc
illinois
2000 beetle, 2015 golf s
2000 beetle. While doing brake pads and rotors, I noticed the front lca rearmost bushings were destroyed. Pulled them out, and one of the front bushings was in really bad shape. Replaced both control arms with new bushings. The sway bar bushings were bad as well.
Now the car pulls slightly to the right accelerating, and slightly to the left on decel. I am guessing that the rear axle beam bushings are bad as well. Could that be what is causing the pull? The rest of the suspension/steering is all new (10-12k miles) with the exception of the inner tie rods.
WildChild80
Nashville, AR
2001 Jetta TDI 2000 Jetta TDI 2000 New Beetle TDI ALL 5 speeds
Did you have an alignment done after the bushings?
Sent from my Pixel XL using Tapatalk
Vince Waldon
Edmonton AB Canada
95% chance somethings still worn out in the front end... *the* most common cause of steering-by-torque. :)
Ball joints? Inner tie rods? Upper strut bearings and/or bushings?
super1
NY
none
Was it doing it before you change bushings?
You sure all LCA nuts & bolts are tight?
Happen to me
scurvy
Good Ol' Boy
Chicago IL USA
2006 Golf
Ball joints were my cause of pulling while accelerating.
Could also be wheel bearings or tie rod ends? Get the front end up on jack stands and spend some time forcing stuff around to find out where the looseness starts.
burn_your_money
Missouri
99 Beetle, 96 B4V, 05 Passat wagon
I was working on a car with the exact same symptoms. I diagnoses a worn strut. The chrome rod rocked back and forth in the strut body. I've never seen that before. I haven't changed it yet so I don't know for sure if that is the issue or not.
Matt-98AHU
Gresham, OR
2001 Golf TDI, 2005 Passat wagon, 2004 Touareg V10.
I've seen not only bad ball joints cause this, but also ball joints where the 3 bolts that secure it to the control arm were not torqued appropriately.
rpm-inc
illinois
Metalnerd lift was installed about 15k ago with new struts and bearings, outer tie rods, and ball joints. It was aligned then, with the ball joints pulled all the way outward. That is where I retightened them.
Before changing the arms, it drove fine, with an occasional pop that I thought was the napa cv axle, but that is gone now. It drives straight and brakes fine, just a slight pull either way. So it has to be inner tie rods, or the now tight front end is making something in the back noticeable.
rpm-inc
illinois
I guess I should have jacked the front end up and wiggled some stuff before I posted. The 10 month old febi driver side outer tie rod end from idparts has a lot of slop. I can move the wheel back and forth and feel the clunk in the rod end. Passenger side seems tight still. The ends were $20 when I bought them, now they are 10 lol.
This rod end is all that idparts sells. Recommendations?
Matt-98AHU
Gresham, OR
TRW is the original supplier of the tie rods on these. If you can find a set of those, that's what I would use.
Lower or lifting a car does change the angles of the tie rods in particular, and they may no longer be angled where they resist wear the best. Sometimes it's just a fact of such a change in suspension geometry that certain parts wear more frequently.
But, my experience has been than OE (or aftermarket Lemforder and TRW) tie rods tend to last longer than Febi or any cheaper aftermarket ones.
sk1pp3r
houston
2000 jetta
I have the exact same issue on my 2000 Jetta MK4 TDI. All steering parts are brand new even bearings are new and it wasnt doing it before parts. Replaced all parts because lower aframe had a blown bushing (probably should have just done the one aframe).
I need to put car back on jacks and do some pulling but thought i would look here and note that i have same issue.
ItAintRodKnock
Fraggle Rock, CO
01GolfTDi
Tranny mounts or motor mounts.
Years ago, my '03 was doing this. I made a joke that I could "change lanes simply by smashing the throttle." The mounts was where i was directed. After you check your front end parts, go ahead and check your motor and tranny mounts.
Sent from my VS987 using Tapatalk
BobnOH
not-a-mechanic
central Ohio
New Beetle 2003 manual
If you don't find anything loose, you might want to have it aligned. If nothing else, they should be able to tell you why it's wandering.
