5th not enginage on highway, but does at idle
Greg5OH
Ortonville MI
13 Q7
Did an auto to 02J swap for a guy. Used trans, no info on it.
1-4, R works. new cable end links, did the factory alignemnt method.
5th gear feels good and engages nice at idle. I can select it, either drag the clutch/creep the car or stall the engine.
Does not engage while driving. Doesnt "feel" there, and when i let the clutch out it grinds and essentially pops out. As though the selector ring is barely hovering over the gear lock.
Bad synchro?
mr.loops
Kelowna
2002 jetta, 2003 Bora 1.8T
Your symptoms do point to a worn/damaged synchro.
Careful removing the gear/ hub assembly- they are on tight and you can easily chip the teeth
ghohouston
Lewisville, Texas
2001 Jetta Sedan TDI 5 Speed
Check the bushings under the shifter knob/shaft. Both alh's I've had, had the little bushings on the cable ends fail. I cut a piece of vacuum hose both times, and it worked flawlessly. Still running tge same tubing for i'd say no less than 70k miles without problem.
