Kill Switch for Anti-Theft?
garciapiano
Southern California
1997 Jetta TDI (1Z)
Hi all,
Has anyone installed a kill switch that disconnects electrical control to the fuel pump relay? I have deleted the factory alarm system but would like to make sure that I can enable a kill switch if I park in a seedy area.
The simplest option is to simply pull relay 109 but I feel that there is a better way to accomplish this.
Does anyone have some details of their install if they have done so?
ToddA1
NJ 08002
'96 B4V, '97 B4 (sold), '97 Jetta (scrapped)
Break and switch a wire to the 109, stop solenoid, CPS, 3rd inj, etc. I don’t do any of them, and likely won’t.
I run aftermarket alarm/remote starters and stopped hooking up the starter kill.
-Todd
Mongler98
COLORADO (SE of Denver)
because, you know, we all hear of our rust buckets getting stolen every day!
just have a good auto policy
bypass the electrical stuff and go right for a shutoff valve on the fuel filter, post fuel filter.
Or a cut off switch on the battery terminal, or my favorite, a manual transmission and a detachable steering wheel from momo
Chris_TDI_98
Hartford, CT
1998 Jetta TDI 1.9L mk3 1Z AHU
You could add a switch (hidden under the knee panel) which interrupts/disconnects the output of relay 109, and also interrupt the output of the ignition switch.
Without 109 output, the engine computer won’t boot up, no ignition.
Without the ignition switch output, no crank.
The car would appear as if it had a dead battery because it’s not even trying to start, yet the interior/exterior lights still come on.
genscripter
Los Angeles
98 Jetta
Why?
You could have the best auto insurance policy on the planet, but once some artar dings your '99 Jetta, the insurance company will deem your car "totalled" because their assessment will be extraordinarily low. They cut you a low-ball check and then you won't have enough money to buy a replacement car. Then you get the privilege of dealing with the DMV and a salvage title! Yippie. :rolleyes:
garciapiano
Southern California
1997 Jetta TDI (1Z)
Some weird ideas here. Cars get stolen all the time, old and new. Auto policies just total cars like ours.
I don’t know why the myth persists that manual transmissions prevent theft. Any car thief worth their salt will be able to steal a manual car.
Also a mechanical valve still allows the car to run and drive for some time before it starves and dies somewhere, which is a considerably worse situation than just preventing starting in the first place.
eddieleephd
Battle Ground, Wa
2002 jetta Wagon
The easiest possible way is to switch the relay 109 signal line from the ECM. It goes to the small post on the 109 and turns it on. If tried to start, it would crank and crank, no start. Another is fuse 43 power to the ECM. Nothing would happen with the key turned.
I don't even lock my car, no one else knows what it is but me.
k_pt
pt
VW MKIV TDI
Also run a wire from 12v ignition to a horn, and put a switch in the middle.
You don't want to give them time to figure out how to bypass the killswitch that prevents from starting the engine.
Put the horn under the seat :D
