WolfgangVW
Hi all. I recently got a 1000w Zerostart coolant heater for my 2003 ALH TDI. Has anyone ever installed one before or have a link for a DIY? I so far have only seen one, also mine came with a plastic Y connector which didn't seem to be used in the DIY I saw, what is this used for? As well the article indicated to remove the check valve, why is this necessary and why is it on the heater originally? Any help is appreciated!
As well as far as plugging it in I have a timer I can use at home, but at work is it OK to let this heater run with no timer for 12 hrs straight ?
Again thanks in advance!
