devonutopia
OK, I know 0.1 is the difference.....
Aside from that though, to the nitty gritty. What really is the difference between these two engines? I just wondered if ever (ok... when....) I have a bottom end meltdown, could I use a 2 litre 8v bottom end to gain a tiddly bit more power? I wondered if the block of the 2.0 is the same as the 1.9, the power is gained via a different crank/rods setup and therefore could also be used as donor parts?
In reality, I think if ever I were to look into bottom end tweaks I would go the whole hog and attempt something to achieve a 2.1 to 2.2 litre capacity....
