monkeytrader
My 2006 TDI had a large oil leak. I first looked at the normal areas. Then after removing the belly cover I noticed a small leak from the pan. I lightly touched it with a flashlight and boom a large leak.
After removing the oil I noticed a perfectly worn area on the pan. After further investigation it was caused by the plastic belly cover rubbing on the aluminum pan.
I've repaired it however I'm concerned about what caused the belly cover to make contact with the oil pan. Any Ideas?
https://www.dropbox.com/s/noyo2xf5gy36hot/IMG_7614.jpg?dl=0
https://www.dropbox.com/s/wulk110aovjg962/IMG_7616.jpg?dl=0
https://www.dropbox.com/s/txpgr0fen8tw519/IMG_7621.jpg?dl=0
https://www.dropbox.com/s/pbn0kjeqagoz6wr/IMG_7625.jpg?dl=0
https://www.dropbox.com/s/piz1vgg2a63qyaf/IMG_7636.jpg?dl=0
