SANman
115k miles on my 2010 JSW TDi 6M and I'm pretty sure either the DMF and / or Clutch has checked out. The wife has driven this car since new, and she's an "okay" shifter but have caught her many times letting out clutch at 2k RPM from a stop. At idle there is a dull knock sound around the tranny. Push the clutch in and the knock goes away. And, after idling or a short drive I have a burning smell. So it's parked until I put the parts together to have a VW mechanic address.
I've decided I will put a DMF back in, as I just don't want to deal with the possible syncro problems of an SMF. The car is not tuned, although if DPF and EGR's start causing problems someday I'll do what I did to my Powerstroke, and get rid of that b.s. But the next clutch needs to last as the Jetta is her only vehicle when I am out of town. I am going to buy one of the Sachs kits with DMF from Darkside.
Would I be better off getting the kit for the CR170 motor, or would it even fit? I'm assuming it would be a heavier unit. Any feedback on my assumptions would be appreciated.
http://www.darksidedevelopments.co....flywheel-and-clutch-kit-for-ppd170-cr170.html
