Go Back   TDIClub Forums > VW TDI Discussion Areas > TDI Motorsports
TDI Motorsports This section is dedicated to the folks who push the TDI to the absolute limit racing. Topics should include articles about TDIs in the SCCA ProRally Series, Drag Racing, AutoCross and any other events that include TDIs.
Old June 23rd, 2017, 12:27   #46
WrEkkED
WrEkkED's Avatar
I want to try a few track days and have a few questions. What size tires do you guys run? I have 8" wheels and was goin to stick with 225 pss. Other than a rear sway bar anything else that's needed to push the car?
Car: koni coils, gtb2260 maxed out stock BEW injectors, stock intercooler, cermaic rear pads, tt bushings, parts in hand going on the car this weekend, h2sport spindles, gli front brakes, ground control camber/caster adjustable mounts.
2004 Jetta TDI Sport Edition
WrEkkED is offline   Reply With Quote
Old June 24th, 2017, 06:34   #47
shepner
Not sure what the limits are on a Mk4 but on my Mk7, I am currently running 225/45/17 RE-71R tires on Enkei Fujin 17x7.5 rims with a bit of extra offset. Ill be switching to 245/45/17 when these wear out. I have heard its possible to cram 255 width in there but there might be a risk of tire rub at steering lock
stephen
shepner is offline   Reply With Quote
Old June 24th, 2017, 06:49   #48
shepner
Realized I forgot to answer the rest of your message...
Depends. Here, the MK7 GTI running at the top of the pro class doesnt have a swaybar. He just jacks up the rear pressure. Some of the other VW guys (who arent slow either) from the Chicago area dont even do that. I did some research and installed a rear swaybar on mine. Just DONT do that in the middle of the season. It will take a while to re-learn the car.
Better, especially if your novice, just drive what you got and go have fun.
stephen
Old June 24th, 2017, 19:48   #49
3L3M3NT
3L3M3NT's Avatar
Are you planning on doing more track days or Autocross?
Either way you'll wanna make sure you have a good set of brake pads and run higher boiling point brake fluid. Like shepner mentioned running a 245/40/17 is about the biggest tire I'd risk running on the car to make sure you clear the fender and strut on the inside in the front. You may wanna look into getting your front fenders rolled if you plan on running a wider tire if you are running your coilovers in their lowest setting.
With the wider tire you'll wanna run a 200 rated treadwear tire to put the power to the ground without bumping you up to the next class if you're doing Autocross.
If you can afford it I'd recommend upgrading your stock BEW injectors for something that will allow you to take full advantage of that gtb turbo you have on your car. Gigger has a set of BEW injectors with +80% Firad nozzles on them that he bought from me when I went with +120% nozzles.
If you are going to be going to some road course events where you'll be out on the track for extended periods of time you may want to at least consider upgrading to an upgrade SMIC or go with a FMIC for maximum efficiency for cooling the air going to the engine. I went with a same side in/out to have the shortest piping run, plus imo the easiest way to run the piping. Like so
Like shepner mentioned, try to do your upgrades at the beginning of the season, so you aren't going to have to reacquaint yourself with the car after you change something. Otherwise good luck, have fun, and stay safe out there.
Sturgeon Bay, WI GTG/Cruise May 20th, 2017
http://forums.tdiclub.com/showthread.php?t=474345
3L3M3NT is offline   Reply With Quote
Old Yesterday, 06:54   #50
WrEkkED
WrEkkED's Avatar
Ok great advice! Ya I would start with some track days at first. Will those 80% nozzles be enough or am I going to wish I did 100 or 120% down the road? I have stock sized rotors on the back but do have ceramic pads. The fronts will be getting slotted gli rotors and cermaic pads too and braided lines all around.
Any good fmic kits that arent a pain? I like darksides kit seems a bit pricey.
Old Yesterday, 21:33   #51
TheFawkingHux
TDI(s): Mk3 Golf CL
195/75R14 Falkens on Snowflakes, Konis, Cabby rear disc swap. It did surprisingly well considering!
97 Golf CL: AHU swap, Race 520's, 11mm pump, CAT filter, EGR delete, FMIC, Malone 3+
TheFawkingHux is offline   Reply With Quote
Fuel mileage for auto TDIs TJett TDI 101 22 April 7th, 2010 10:53
4 New auto TDIs in stock and discounting!! SCEHAR TDI Cars for Sale/Wanted 0 October 23rd, 2006 08:27
Volkswagen Racing UK TDIs VW Derf TDI Motorsports 5 November 26th, 2002 14:45
TDI Goes Auto-X Racing. JOE OLEARY TDI Power Enhancements 20 September 1st, 2001 06:17
Auto Tranny gearing in NB TDIs HowardZ TDI Fuel Economy 4 March 20th, 2000 00:02
Page generated in 0.12823 seconds with 12 queries
[Output: 78.71 Kb. compressed to 69.30 Kb. by saving 9.41 Kb. (11.95%)]
