Old April 6th, 2017, 19:06   #31
jshwamie
Fuel Economy: 38 mpg
Anyone good with logs that can share some input on them?
Sent from my SAMSUNG-SM-N920A using Tapatalk
3 Dr 2000 Volkswagen Golf TDi. SMIC with 2.5 lower pipe. 11 mm pump & lift pump, Bosio Sprint 520 nozzles, Kerma TDi Long Runner manifold so no EGR, stock gt1749v turbo, stage 3 RC, VR6 Clutch, shifter work, 2.5 DP turbo back exhaust. Spec-D head lights, Bilstein shocks & springs sitting on 17's with aftermarket leather seats.
jshwamie is offline   Reply With Quote
Old April 6th, 2017, 19:19   #32
Owain@malonetuning
You're getting boost spikes at lower RPMs, would personally like to see that boost specified taper off 100-150mbar up top too but that's tuning related and not a big deal. Since you can only see 2-3 blocks of boost spike there there's probably even worse in some scenarios, which would explain the limp mode. It's not safe to drive hard as is. The return line obviously has oil on it.
Look at boost specified versus actual. The actual values shouldn't be more than 100-150mbar over. You're maxing the turbo at lower RPMs, fueling should be reduced or actuator adjustment might be needed. I'd start by bumping the IQ up a bunch to see if that remedies things, assuming you have excessive fuel.
Dealers - malonetuning.com/dealers
We made a free VCDS Log Viewer!
Owain@malonetuning is offline   Reply With Quote
Old April 9th, 2017, 20:46   #33
jshwamie
Aah okay, I see what your saying. Strange this just came out of no where. I'll investigate this further with my mechanic friend. I'll also adjust that IQ as you suggested and see what that does for me, or actuator if no change. Thanks bunch for the input.
Whags your take on the oil on the return oil feed line? Wonder if there is a gasket or something in there that is shot? Looking back at my repair logs for the vehicle. Looks like in 2011 the previous owner replaced the oil feed line.
Old April 10th, 2017, 13:07   #34
Nevada_TDI
Awhile back my turbo started over boosting for no apparent reason: the lock nut on my actuator rod came loose and the rod vibrated to the shortest possible position creating the worst case of over boost I had ever seen. Although this may not be your problem exactly, if the return spring in the actuator is getting tired it may not be extending the arm as it should also causing over boost. When over boost comes out of nowhere and is not caused by dirty vanes, one of the two examples given is sometimes the cause.
_______________
2001 Jetta GL TDI, Tinted, Vented, No Kitty, EGR-ectomy, TDTuning, HIFLO .216's, TurboLabAmerica Hybrid 15-17/56, VCDS Hex+CAN, S-B Daily Driver 2 Clutch, DG Short Shifter, Frostheater, Baldwin Fuel Filter, Koni Orange, New Paint. Previous Diesel: 1983 Rabbit Diesel
Nevada_TDI is offline   Reply With Quote
Old April 10th, 2017, 13:23   #35
Owain@malonetuning
That intake manifold would be better suited for a heavily modified car, see boost spike issues with them on PDs, and if your fueling is too aggressive that would cause problems as well. Judging by the fact that your boost is always over, it's probably either excessive fueling or incorrect actuator position/turbo issue. If it's not billowing smoke out the rear view mirror it's likely a physical issue. O rings on the return line might have been re-used, or they might not be tight enough.
Old January 11th, 2018, 19:12   #36
jshwamie
Owain@malonetuning & Nevada_TDI. Wow I Didn't know yall commented. Very good input Thanks a lot. I noticed that there is a lot of oil around the turbo. See image below... If it works..
https://photos.app.goo.gl/0Eptu5FHnlETpF4R2
Old January 11th, 2018, 19:51   #37
Nevada_TDI
I just looked at the picture and I wonder if the two bolts holding the drain line on are tight?
I only bring this up as I had a similar looking oil leak a while back and it did not occur to me the bolts holding on the drain line could be loose. Mine were.
_______________
Old November 15th, 2019, 22:55   #38
jshwamie
Just an update. I didn't take care of it in time. There was no real signs of complete failure coming until it was too late. Suddenly had no power and I could hear.. Noises.
The turbo failed and drained the engine of oil dumping it all into the Intercooler. Because of this the cylinder head was deprived of lube and the sprocket that transfers the power from the cam, to the timing belt. Yeah that sprocket broke str8 off.
Result? Broken cam of course, because of this the lobes and journals were destroyed. Warped cracked cylinder head. No damage thankfully to bottom.
Sent from my moto e5 play using Tapatalk
Old November 16th, 2019, 00:28   #39
Nero Morg
Nero Morg's Avatar
Pictures? Be interesting to see the carnage.
Whatever. Just use your darned blinker. And stay off your phone.
Nero Morg is offline   Reply With Quote
Old November 16th, 2019, 23:55   #40
adamss24
Fuel Economy: 35-45mpg
I would make sure rods are not bent...get a 2nd hand cyl head and fit it along with pd150 head bolts and INA genuine tappets. Fit a new timing belt kit or good measure too !
adamss24 is offline   Reply With Quote
Old November 17th, 2019, 00:12   #41
jshwamie
Yeah I got some photos I'll dig them up. The cartridge failed and the wheel spun out. I pulled pieces of it out of my intercooler.
As for the pistons I have one of the best diesel mechanics in the vw game as my brother in law he thinks it's good, however without xraying it and checking pistons there no way to know. I just can't afford that atm.
I sourced another tdi and took the cylinder head off of that one. I should have done the whole thing but my working conditions where not ideal where it was.
Old November 18th, 2019, 00:06   #42
adamss24
Get the pistons as high as they go in the block and measure their protrusion, if rods are bent the engine wont last long !
3 Bar map upgrade tuning? jshwamie VW MKV-A5 Golf/Jettas 4 March 6th, 2017 22:01
17/22 wanted piping for upgrade 3 bar map sensor too Moesauction! Private TDI Items for Sale/Wanted 3 March 15th, 2015 14:12
3 Bar Map for ALH droppedjet Private TDI Items for Sale/Wanted 11 December 3rd, 2009 06:33
3 bar MAP sensor + stock tuning/turbo... DBDieseler TDI Power Enhancements 12 January 14th, 2009 23:55
3 bar map sensor upgrade? danielhf TDI Power Enhancements 3 November 12th, 2007 04:56
Page generated in 0.17460 seconds with 11 queries
[Output: 116.24 Kb. compressed to 98.64 Kb. by saving 17.60 Kb. (15.14%)]
