Old October 16th, 2014, 19:02   #1
sparkyk
TDI(s): 2005 golf
Default Help, 2005 golf stalled and won't start
I have a 2005 golf, 1.9L, 5 speed manual with 140,000 miles. I was driving down the highway at 80mph and my car stalled and the temperature warning light came on. I coasted to a stop and while waiting for it to cool down I noticed my coolant reservoir had ample coolant in it. There was no steam present like in most overheat situations, so I don't know if it actually overheated. The car cranks as normal, but the car still wouldn't start a couple of days later, so I replaced my fuel pump and relay 109. The ASV is open. The timing belt and water pump were replaced about 35,000 miles ago and the belt still appears to be in good condition. Please help me get her running again. Thank you.
sparkyk is offline   Reply With Quote
Old October 19th, 2014, 07:07   #2
sparkyk
TDI(s): 2005 golf
Bump for help. Any ideas guys?
Old October 19th, 2014, 10:26   #3
jimbote
jimbote's Avatar
unhook the boost pipe from the intake and try cranking
Old October 19th, 2014, 12:04   #4
sparkyk
TDI(s): 2005 golf
I unhooked boost pipe and mityvaced the return from tandem pump at the T. Had good fuel without bubbles. Still no start.
Old October 19th, 2014, 12:08   #5
whitedog
You have a pump in the tank so you don't need to worry about air in the fuel system. You can remove the line coming out of the filter to the head and turn the key on to see if you get fuel coming out.
You can check for codes.
Does the tach register when cranking the engine?
Old October 19th, 2014, 12:22   #6
sparkyk
TDI(s): 2005 golf
Fuel comes out after the filter when cranking. I can't check codes until tomorrow, and my tach registers when cranking. I just bought a cheap reader though because I don't have the money for a ross tech right now, so hopefully it will still be able to tell me something
Old October 19th, 2014, 12:25   #7
sparkyk
TDI(s): 2005 golf
I also get fuel back to the T on the filter when cranking, but not as much that comes out of the filter. I dont know if its restricted inside of the tandem pump or if its supposed to be like that.
Old October 20th, 2014, 13:11   #8
Dimitri16V
Dimitri16V's Avatar
check the timing belt . sounds like the water pump seized and shredded the belt
2004 Golf TDi 412K, 87 Rocco
2016 Toyota Corolla S
2016 Golf TSI ( reinforced metal oil pan , VCDS tweaks)
Aleksander Prokhorenko , Charles Keating ,Russian and US special forces KIA against ISIS. RIP heroes
Dimitri16V is offline   Reply With Quote
Old October 20th, 2014, 14:05   #9
JB05
Fuel Economy: 43/41/40
Flakey or faulty crank shaft position sensor might be the culprit.
JB05 is offline   Reply With Quote
Old October 20th, 2014, 14:44   #10
pruzink
Fuel Economy: 42
When a car stalls, a bunch of the warning lights come on. If the coolant warning came on by itself, then I might fear that Dimitri16V above could be correct in his diagnosis. I also agree with JB05 that a bad crank shaft speed sensor will prevent the engine from running (when mine was failing it didn't set any check engine codes).
pruzink is offline   Reply With Quote
Old October 20th, 2014, 15:43   #11
sparkyk
TDI(s): 2005 golf
Ok, my scanner came in today. I have 3 glow plug sensor troubles, which is due to a faulty harness. I have known about this for a while as the new harness is in the garage waiting to be installed. I also have code 17987 which is an immobilizer issue and 19464 cam shaft sensor. Would the cam shaft sensor cause the immobilizer issue? How do I fix it? Also will erasing these codes cause any issues? Also, my timing belt appears to be in good condition.
Old October 20th, 2014, 20:17   #12
LNXGUY
LNXGUY's Avatar
Cam sensor shouldn't stop the car from starting (Although the crank sensor will).. The Imb fault might the culprit here.
Bill
LNXGUY is offline   Reply With Quote
Old October 21st, 2014, 16:27   #13
sparkyk
TDI(s): 2005 golf
Water pump seized. God willing nothing in the motor is trashed. Pray for no bent valves
Old October 21st, 2014, 17:39   #14
Dimitri16V
Dimitri16V's Avatar
I was hoping I was wrong
for the record , who was the water pump manufacturer ?
Old October 21st, 2014, 17:44   #15
whitedog
Seized water pump means teeth stripped off of the belt. Teeth stripped off of the belt means it's probably out of time.
Before pulling anything apart, check the timing relationship of the crank, and cam. If they are more than two teeth off at the cam, you need to pull the head and inspect for valve to piston contact.
'05 Golf stalled and won't start bf1967 VW MKIV-A4 TDIs (VE and PD) 14 November 25th, 2010 22:52
Engine Stalled, Now Won't Start. Please Help... Big Jimmy VW MKIV-A4 TDIs (VE and PD) 21 January 27th, 2010 08:20
stalled and now won't start massey860 TDI 101 16 March 22nd, 2009 21:38
2005 TDI - loss of power, stalled, and won't start (noob) pinkfreud55 TDI 101 35 January 16th, 2008 05:45
Won't start after it stalled out. dmulert VW MKIII-A3/B4 TDIs 4 July 27th, 2007 10:54
Page generated in 0.17382 seconds with 11 queries
[Output: 119.69 Kb. compressed to 98.99 Kb. by saving 20.70 Kb. (17.30%)]
