Old September 17th, 2012, 11:01   #1
witchcraftz
witchcraftz's Avatar
Fuel Economy: 46 mpg
Post MK4 HID Projector setup wiring diagram
Here are some clean wiring diagrams on how to connect an HID projector setup in both single beam xenon without a shutter, and in a bi-xenon with shutter projector.
Stock setup
Single beam xenon projector without a shutter
Bi-xenon projector with shutter
witchcraftz is offline   Reply With Quote
Old September 17th, 2012, 11:57   #2
Birdman
Fuel Economy: 55 summer 50 winter
Ok so what is the best legal looking setup. I have to pass inspection every year and they check for High and low beams, turn signals and running lights. I hope to replace my damaged E-code this winter and want a brighter setup, while still looking legal, OEM EURO HID's are a bit to high. Looking for something in the 400-600$ range.
2003 Jetta 216 injectors, race pipe, OMI, 2.5 cat back pipe, Sachs power clutch,Lightweight fly wheel,Rocketchip 3.0,Dieselgeek race pipe,Borla SS exhaust,Dieselgeek Intercooler pipes,Pierburg MAF,EU cluster with LED Boost gauge,,
Ventectomy,Alientech window,Old Navy ccv filter,Catch can,Dieselgeek short shifter,ATE power slot rotors,Porterfield pads,Shine suspension,Shine rear sway bar,TT pedals & foot rest,Cat fuel filter 2 micron,Alum skid plate,Euro headlights and switch,5 Brake light mod.
Birdman is offline   Reply With Quote
Old September 17th, 2012, 12:41   #3
witchcraftz
You can find reproduction HID OEM headlight look alikes at that price.
Old September 18th, 2012, 22:05   #4
Birdman
I have been looking at them but I need to make sure I get a well made set like Hella's. I have until February to get them so can afford to take my time and see what others are using and saying about them. I may have to go over to Vortex and see what they have to say. Your wiring diagrams will save me from hunting for those,
Old September 19th, 2012, 08:14   #5
mrvermin
mrvermin's Avatar
Check with "Vancity" and "Mike@VolxTuning" on the Vendors section, they both sell the OEM Rep HID sets.
Or check with "JettaSportTDi" as he builds HID Retrofits, also in the Vendors section.
MrVermin
NEW: 2011 Golf Sportwagen Highline, Navi, DSG, Pano-Roof
OLD: 2001 Jetta TDI: 6speed ERF swap, Fully Built Block & Head, RC Tuned, Race520's,
Colt Stage2 Cam, PD150 Intake, PD150 RacePipe, VNT17/22, OMI, 3" Full Exhaust, 3BAR MAP, 11mm IP, Defender Skidplate, 17" Ariettas, GLI Suspension, Audi TT LCA Bushings,
mrvermin is offline   Reply With Quote
Old November 29th, 2012, 07:45   #6
Robo48
I'm wondering if you can activate the solenoid off of the "factory" wiring inside the headlight? Seems the high beam wires are already there no? could you just wire them inside and skip the extra penetrations of the housing?
Robo48 is offline   Reply With Quote
FS: MK4 DEPO Projector Headlights + HID freakwithracket Private TDI Items for Sale/Wanted 4 May 31st, 2012 13:09
Golf/Jetta MKV Hella hid-look projector headlights with 6000k HID kit zimm17 Private TDI Items for Sale/Wanted 4 May 3rd, 2012 11:25
MK4 ALH Downpipe, Intercooler setup, wiring harness, airbox k_harley Private TDI Items for Sale/Wanted 1 February 13th, 2012 19:23
mk4 golf tdi wiring diagram homerhobson VW MKIV-A4 TDIs (VE and PD) 2 January 12th, 2012 20:02
Mk4 rear fog euro wiring diagram needed. turbocharged798 Upgrades (non TDI Engine related) 26 August 24th, 2011 04:46
Page generated in 0.14653 seconds with 11 queries
[Output: 75.45 Kb. compressed to 66.26 Kb. by saving 9.19 Kb. (12.18%)]
