Alright, I was going to make my own thread for this but I see this thread is still extremely active so I will try here first.
I've had my 01M 2000 Jetta for 10 days now. I fixed the solenoid issues the automatic had, tossed in a new filter and flushed it out with new fluid, however I think a valve issue still exists.
I planned on doing a 5-speed swap anyway, and I just happened to stumble upon a 1999.5 VR6 5-Speed car with a bad engine for less than a used trans would cost me from a boneyard. Even for the small parts alone its a "no brainer" to pick it up.
It seems that the electrical side of things seems to be the hardest part for people to tackle, I downloaded the Word Doc on page one and seems pretty straight forward.
My main questions are;
With exception to VAG-COM and picking up a Manual TDI starter, should I technically have EVERYTHING I need to do this swap since I will have a complete parts car? Or is there something else I'll need to buy?
The VR6 Flywheel, Clutch & P. Plate. I believe these will all work with the TDI correct? Are they ideal? I dont plan on making this into a race car and the VR6 has more HP and Torque than the TDI, so stock stuff should be no problem?
EDIT: ok, so the famed G60 clutch is the same that is in this 99.5 Jetta, so it should be fine for me. The funny thing is, I can get a replacement Clutch/P. Plate Kit for $361.63 my cost, or I can get a single mass Flywheel conversion kit, which also includes the Clutch, P. Plate, T. Bearing, all necessary bolts, ect.... for $371.65?? Damn, I cant pass up a $10.02 Flywheel & Hardware!
I dont think the 99.5 Trans will allow me to use the nice short shifter, are their other options I have no stumbled upon yet?
