Old August 3rd, 2006, 16:08   #1
thedobber
Question putting an 02 jetta tdi into a 99 beetle tdi
I had the unfortunate experience of my 1999 beetle tdi "dropping a valve" on the highway. I soon found out how expensive a replacement longblock was. I needed at least a long block because the valve train came apart and damaged the head and cylinders. I found a used complete 2002 jetta 1.9 L TDI.
The swap seems to be going smoothly until I get to the injector pump. The 2002 looks different than the 1999. Will it work? and if so does anyone know the wiring color mapping? It has different color wires and a different connector. I don't want to screw something up. will the ECM have to be changed or reprogramed?
It the 2002 pump won't work, is it OK to put the 1999 pump on the 02 motor? Everything else seems to interchange just fine.
thedobber is offline   Reply With Quote
Old August 3rd, 2006, 22:01   #2
compu_85
Gadget Guy
compu_85's Avatar
Fuel Economy: 3.3 Mi/kWh
Should be exactly the same. Did both cars originally have the same type of transmission?
Any pictures?
-Jason
Present:
2018 Tesla Model 3 DM. 50,000 miles.
2014 Cadillac ELR. 38,000 miles.
2013 Fiat 500e. 32,000 miles.
Past:
99.5 Jetta "GLX" TDI. 323,000 miles. Power Memory Seats, HIDs 11mm pump, BV39 Turbo, RCIII 36/47 MPG. Sold to JDSwann's Brother.
2012 Passat SE TDI DSG. 114,000 miles. LED tails, Memory Seat, HIDs. Bought back by VW.
2004 Touareg V10 TDI. 165,000 miles. Sold to Matt98AHU w/ flat camshafts.
Thank you for giving me the BUG*PWR award. It means a lot to me!
Old August 4th, 2006, 07:18   #3
thedobber
Default tdi swap
yes same transmission, both 5 speeds. I don't have any pics but I'll try to get some on later tonight or this weekend.
Any idea on the wiring harness color differnces? I would rather use the newer injector pump if possible.
Old August 4th, 2006, 14:17   #4
compu_85
Gadget Guy
compu_85's Avatar
Is the plug on the end the same? You shouldn't have to cut wires.
-Jason
Old August 14th, 2006, 03:45   #5
ninedee_golf_tdi
Are the injector plugs different between a manual tranny and an auto ? Just a thought.
ninedee_golf_tdi is offline   Reply With Quote
Page generated in 0.12782 seconds with 10 queries
[Output: 65.47 Kb. compressed to 57.72 Kb. by saving 7.75 Kb. (11.84%)]
