Old November 18th, 2019, 09:43   #16
wonneber
Originally Posted by 2002silverTDI View Post
I'm only getting bits and pieces of information from him since he isn't a car tech guy.
He did not tell me if the charge light came on in the dash.
You trust the car to someone who "isn't a car tech guy" ??
To me the dash light isn't much more then a warning the belt broke.
wonneber is offline   Reply With Quote
Old November 18th, 2019, 10:11   #17
jokila
jokila's Avatar
Fuel Economy: 52/45/40
It seems to me he is referring to his son.
Ventecomy | Heated seat lighted switch | W8 light |
Blue tint aspherical tinted mirrors | Turn signal convenience | Euro Light Switch | Rear Fog Light | DrawTite Hitch | HIDs | 520 injectors | Engine Cover mod | Homelink visor
VCDS-HEX/CAN available Houston metro area.
jokila is offline   Reply With Quote
Old November 19th, 2019, 05:34   #18
roadhard1960
Fuel Economy: 48 mpg
To the guy that put a new regulator/brush pack in. I did the same thing. A year later I heard some noises but could not figure from where. My alternator started a fire. I happen to drink water when driving so I doused it with 2 liters of water after stopping and called a flatbed tow. I put in a new Bosch (made in China) alternator. It is about due for preventative maintenance alternator work. That will be new bearings, new regulator and probably a new clutch.
My truck was squeaking so I replaced all the idler bearings and water pump. A year later it is squeaking again so I put in the generator repair kit which had bearings and brushes. I had to turn down the slip ring on the rotor as it was grooved. Chrysler calls that thing a generator in the repair manual. Note that the bearing did not seem to be particularly worrisome on the bench but the generator was quiet with new bearings. Hence the agreement with the other guy who said his go to rebuilder does new bearings whenever he repairs an alternator. That said I have a Bosch router that has odd non-standard bearings no longer available. I squeezed some grease in the bearings and the router no longer screams like a banshee.
2003 Jetta wagon GLS, 5 Speed, Alligator tune, 34 psi tire pressure, 49.1 US mpg first 35k, 50 next 31.5k, 50.4 next 36k miles, cleaned intake twice and polished end runners last time, Mobil Truck & SUV or Delvac. Koni FSDs, VWs since 1977. Sprint 520 Nozzles for Christmas 2007. Ecodes with fogs and Eswitch. 571,000 miles and counting, original turbo. 2004 Dodge 2500 Cummins HO.
roadhard1960 is offline   Reply With Quote
Old November 19th, 2019, 20:55   #19
2002silverTDI
TDI(s): Jetta TDI
Break in the case!
I heard that a power steering line had a slow leak and was dripping fluid on the alternator.
The shop in Atlanta fixed the leak and the new alternator is in.
Hopefully this one will last!
@wonneber: My son loves the car. He's just not a mechanically inclined, technical person.
2002silverTDI is offline   Reply With Quote
Old November 20th, 2019, 10:53   #20
wonneber
Sorry, didn't realize it was your son.
Old November 20th, 2019, 18:55   #21
2002silverTDI
TDI(s): Jetta TDI
@wonneber: No worries.
A 99 cent o-ring caused a lot of mayhem.
An o-ring brought the Space Shuttle crashing down!
Are the alternators same? 98 Jetta and 96 B4 jdulle VW MKIII-A3/B4 TDIs 2 October 24th, 2019 17:09
02 TDI jetta swapped into 02 VR Wagon jmac015 TDI Conversions 0 November 16th, 2016 11:47
2006 & 2013 Jetta Alternators Interchangable? striker VW MKV-A5 Golf/Jettas 5 November 29th, 2013 12:20
02 beetle TDI n 02 Jetta TDI NorthernVdub VW MKIV-A4 TDIs (VE and PD) 3 August 1st, 2012 06:16
WTT 02 Civic Si for )01/02 Jetta Tdi OUSooner TDI Cars for Sale/Wanted 8 April 9th, 2004 22:31
Page generated in 0.13756 seconds with 13 queries
[Output: 76.45 Kb. compressed to 67.33 Kb. by saving 9.11 Kb. (11.92%)]
