Rough start
MrBigTruck
Kansas, USA
2000 Beetle, 2000 GTI ALH swap, 2006 Jetta, 2006 Jetta, 2008 Mercedes GL320 CDI
Might be losing a little prime from the check valve in the tandem pump going bad so it takes a second for the fuel to get to the injectors.
MrBigTruck
Kansas, USA
You can put a cheap check valve in the fuel line too but the only way to fix it right is a new tandem pump.
