tdi54
- Joined
- Dec 19, 2010
- Location
- California
- TDI
- 1981 Rabbit Diesel(sold), 2009 Jetta TDI MT(sold)2010 Jetta TDI MT, 2015 Jetta TDI SEL, DSG, 99 Ford F 350 PSD Dually, 2016 BMW X5 xDrive35d, 2016 535d
Hello,
This afternoon coming from work,the check engine light came on. Checking fault code with vcds it showed below fault code.
How difficult it is to change the temperature sensor? From what I read, there could be a second temperature sensor, does that one need to be changed too?
Lastly, could this issue be covered under Dieselgate warranty?
Thank you in advance for the help..
1 Fault Found:
008581 - Engine Coolant Temp Sensor on Radiator Outlet (G83)
P2185 - 000 - Signal too High - Intermittent - MIL ON
Freeze Frame:
Fault Status: 10100000
Fault Priority: 2
Fault Frequency: 2
Reset counter: 255
Mileage: 363741 km
Time Indication: 0
Date: 2050.14.22
Time: 17:05:15
Freeze Frame:
RPM: 1196 /min
Speed: 71.0 km/h
Temperature: 43.2°C
Temperature: 76.5°C
Temperature: -29.7°C
Temperature: 50.4°C
Temperature: 42.3°C
1 Fault Found:
Freeze Frame:
Fault Priority: 2
Fault Frequency: 2
Reset counter: 255
Mileage: 363741 km
Time Indication: 0
Date: 2050.14.22
Time: 17:05:15
Freeze Frame:
RPM: 1196 /min
Speed: 71.0 km/h
Temperature: 43.2°C
Temperature: 76.5°C
Temperature: 50.4°C
Temperature: 42.3°C
