Sprocket
Sprockette's hubby
- Joined
- Nov 18, 2004
- Location
- MI
- TDI
- 2014 Jeep Grand Cherokee Summit Eco Diesel, 2005 Passat Silverstone Grey, 1996 Passat Storm Grey
I have a couple of electrical issues I need help to figure out please.
First is the cruise control function does not work when my headlights are turned on. I have a Euro headlight switch and CC works with the following: with the headlights off, parking lights / DRLs on, fog lights on.
The second I move the headlight switch to turn the headlights on, CC disengages, and will not resume. Totally not functional with the headlights on.
If I turn the headlights off, CC will work again. I hit the set or resume button and it functions normally.
Here are some pictures showing what's happening in VCDS. I'm not sure if these are normal readings or not and was hoping someone could check their car as well and report back.
Cruise control switch off & headlight switch off:
Cruise control switch off & headlight switch on:
Cruise control switch on & headlight switch off:
Cruise control switch on & headlight switch on:
Next up is the random function of all of my door locks. I thought this was due to the car sitting for months on end and they all seemed to work off and on with the rear passenger side and driver side door giving me the most issues. They cleared up for a while, but the rear passenger side was giving me the most issues, so I ordered a new door lock latch actuator, then it cleared up and the driver front door started acting up.
I'm unsure if these are all lock actuator issues or something else electrical causing the random issues.
If I use my physical key to manually lock the drivers front door, all locks function as they should and lock.
If I use my physical key to manually unlock the drivers front door, all of the locks (except for the passenger rear) will unlock like they should. Passenger rear door is intermittent though.
Here is the VCDS scan:
Sunday,08,April,2018,13:04:41:03916
VCDS -- Windows Based VAG/VAS Emulator Running on Windows 10 x64
VCDS Version: 18.2.0.3 (x64)
Data version: 20180212 DS287.0
www.Ross-Tech.com
Chassis Type: 3B (3B - VW Passat B5 (1997 > 2005))
Scan: 01 02 03 08 15 16 17 19 35 36 37 46 47 55 56 57 58 75 76 77
VIN: WVWAE63B75E037384 Mileage: 228720km-142120miles
Address 01: Engine Labels: 038-906-016-BHW.lbl
Part No SW: 038 997 016 T HW: 028 101 198 2
Component: R4 2,0L EDC G000SG 0314
Revision: 12345678 Serial number: VWZ7Z0D0237910
Coding: 0150031
Shop #: WSC 66565 257 00032
VCID: 2F6DA95ABD12003CB1-5140
No fault code found.
Readiness: 0 0 0 0 X
Address 03: ABS Brakes Labels: 4B0-614-517.lbl
Part No: 4B0 614 517 G
Component: ABS/ESP front 3428
Coding: 04255
Shop #: WSC 05311
VCID: 25414B72BFEE4A6C4B-5124
Part No: 1C0 909 605 C
Component: 09 AIRBAG VW61 04 0003
Coding: 12345
Shop #: WSC 05311
VCID: 24475676B4D4B3645C-5124
Address 16: Steering wheel Labels: 1J0-907-487-A.lbl
Part No: 1J0 907 487 A
Component: Lenkradelektronik 0005
Coding: 00118
Shop #: WSC 05311
VCID: 2F6DA95AED12003CB1-515E
Address 17: Instruments Labels: 3B0-920-xx5-17.lbl
Part No: 3B0 920 929 C
Component: KOMBI+WEGFAHRSP VDO V04
Coding: 13235
Shop #: WSC 00000
VCID: 275D417AC5E2587C79-5124
WVWAE63B75E037384 VWZ7Z0D0237910
2 Faults Found:
01336 - Company Data Bus for Comfort System
49-10 - No Communications - Intermittent
01304 - Radio
49-00 - No Communications
Part No: 6N0 909 901
Coding: 00006
Shop #: WSC 05311
VCID: 70EF6A2630AC5FC4E8-5124
2 Faults Found:
01304 - Radio
Address 46: Central Conv. Labels: 1C0-959-799.lbl
Part No: 1C0 959 799 C
Component: 08 Komfortgerát HLO 0004
Coding: 00259
Shop #: WSC 05311
VCID: 377D913A1542C8FCE9-4B1C
Subsystem 1 - Part No: 1C1959801
Component: 08 Tõrsteuer.FS KLO 0202
Subsystem 2 - Part No: 1C1959802
Component: 08 Tõrsteuer.BF KLO 0202
Subsystem 3 - Part No: 1C0959811
Component: 08 Tõrsteuer.HL KLO 0202
Subsystem 4 - Part No: 1C0959812
Component: 08 Tõrsteuer.HR KLO 0202
4 Faults Found:
00928 - Locking Module for Central Locking; Front Driver Side (F220)
27-00 - Implausible Signal
00929 - Locking Module for Central Locking; Front Passenger Side (F221)
27-10 - Implausible Signal - Intermittent
00930 - Locking Module for Central Locking; Rear Left (F222)
00931 - Locking Module for Central Locking; Rear Right (F223)
End-------------------------(Elapsed Time: 04:40)--------------------------
www.Ross-Tech.com
Coding: 0150031
Coding: 04255
Shop #: WSC 05311
Coding: 12345
Shop #: WSC 05311
Coding: 00118
Shop #: WSC 05311
Coding: 13235
Shop #: WSC 00000
2 Faults Found:
01304 - Radio
Coding: 00006
Shop #: WSC 05311
2 Faults Found:
01304 - Radio
Coding: 00259
Shop #: WSC 05311
4 Faults Found:
