Oh yeah, the bore of it is wasted. Not sure if some trash got into the pump and machined the bore or if it is just because the pump has 280k miles on it. Either way, it'll need a new pumpHard to see... is it scored or something?
How did the advance mechanism feel? It was binding or not rotating smoothly?
-Todd
It is the same pump, yes. Swapped from the cam plate out to the delivery valves out of an 11mm ALH pump.Bad news... from the pic, it looks normal to me. I just pulled the head from my project’s pump to check for rust/varnish and that one ring I see, is supposed to be there.
If you had the pump resting with pressure on the mainshaft, the roller cage and piston will not move smoothly.
Was this the pump that you swapped the 11mm internals into?
-Todd
Yep...Ah, now I think I’m seeing it.... it’s in front of the hole that the roller cage pin would be dropping into the advance piston.
-Todd
I 100% agree. Just a big coincidence, I guess. Everything has to break at some point. I guess it was just that pump's time.Just strange that the pump with the same wear a few months ago ran fine.
