Does anyone know if DashCommand will monitor various EGTs? Does anyone us an app that can monitor EGTs for iPhone?
Thanks!
I have DashCommand, but it's been a little wonky on what parameters it reads and what it doesn't seem to register (I have a Veepeak WiFi OBD2 OBD II Super Mini). I'm not sure if the failure to register some values (e.g. boost) is a function of the App's configuration or the OBD transmitter.
That, plus the fact that it's inconvenient to go into the app every time i drive, means i don't use it much, but here's what i remember:
EGT is not one of the default readouts on the dashboards. You can do custom dashboards, but i haven't played around with it too much yet.
"Catalyst" temp is one of the parameters it was reading correctly, and I have been able to use that to check for regeneration, if that's what you are after.
