dweisel
The danger in a fuel line leaking is that the spray mist may be ignited by an ignition sourse.A cracked fuel line under pressure will put out a fine mist of fuel that will burn like a flame thrower. Usually something sopping wet with diesel fuel is somewhat harder to get burning. So, even though your car was soaking wet with diesel fuel the fire hazard was low to moderate.Two stupid questions:
- My car had a fuel leak (not related to the resonance thing), and ended up spewing 3-4 gallons of fuel all over the engine compartment, along the bottom-side of the car, and up onto the rear hatch (the fuel flowed like this because I was driving at highway speeds). How much danger was I in? I thought diesel fuel mainly combusted under pressure, thereby reducing the risk.
- Why are original owners treated differently from used car owners? A pattern failure is a pattern failure, regardless of who owns the car.
As far as the original owner compared to a used car owner getting out of warranty repairs done under warranty. The new car is sold by a VW dealer and therefore is backed by VW,somethimes even when out of warranty. A used car is sold in several different ways. Private individual,used car lot or at a VW Dealership. VW is not going to cover a used car sold by and independent used car dealership or a private individual if its out of warranty. You may have a better chance with a used car sold at a VW dealership.
