Fault code P0087 and P00C6 with loss of power
How to diy fix the much dreaded poo87 low fuel pressure
  • Diy fix or replace the sensor on common rail
    Votes: 0 0.0%
  • Diy fix or replace the fuel regulator valve
    Votes: 0 0.0%
  • Diy fix or replace the fuel metering valve
    Votes: 0 0.0%
  • Diy fix or replace the hpfp
    Votes: 0 0.0%
  • Total voters
    0
  • Poll closed .
Deezar
Portsmouth uk
Vw passat 2012 1.6 tdi bluemotion
I have a vw passat 2012 , 1.6 tdi bluemotion i ve been driving this car for 6 months now and has gave me few problems so far but the latest is loss of power and fault codes p0087 and followed by p00c6 warning lights come up on the dash as well, took it down the garage and ask them to change the fuel filter in case it solves the problem, but it dident and they wanted to keep car for further tests with the most dŕeading scenario a hpfp or if am lucky a regulator or a sensor ....u could pay this guys 2 hours to test your car and they can still turn around and say we not sure whats wrong take it to dealers..anyone else had similar problems and can it be fixed with basic diy at home ?
