JamesK89
Tell me if this makes any sense to you guys because it certainly doesn't to me.
So I've had my baby; a 2010 Jetta Sportwagen TDI I4 2.0L with ~98,000 miles on the odometer, for a few months now and I've had the non-stop problem of the clutch suddenly and seemingly randomly acting up by sticking and/or not springing back from the floor. I had changed the clutch master cylinder and then over time bled the system several times but any time I managed to get it working reliably it'd randomly act up again.
However it is important to mention that the brake hydraulics I've never had a problem with, but I recently changed the front brake pads which were nearly worn out and, while replacing them, I of course pushed back the caliper piston.
So now for the real puzzling part:
Last night I was doing routine maintenance during which I changed the oil* before heading to Wally world and I noticed the clutch felt firmer than ever before and the whole trip (about 30 miles worth counting both ways) the clutch pedal remained firm and never got sticky or stayed on the floor like it had before but to be sure I checked it a couple of hours after I got home and this morning I drove it to go and get breakfast and sure enough, to my amazement, the clutch pedal was still working amazingly.
The oil that I drained out was very thick and very black and the old oil filter didn't look to be in too good of a condition, so my theory, if it is related, that the old black syrupy oil, which I have no idea when it was last changed by previous owner, was somehow affecting the vacuum pump degrading the performance of the hydraulics.
Is this a mere coincidence or could changing the engine oil somehow improve the hydraulics? Any thoughts?
* I used a new OEM oil filter from vwpartsvortex and the TOTAL Quartz INEO Long Life sythentic 5w30 diesel oil approved by VW
