Wilkins
I have read through most of the major threads relating to improving the handling of the A4 and so far I haven't found much discussion about the effect on ride comfort and steering feedback from changing the rear lower control arm bushings to the solid Audi TT version. Can someone who has done this provide some comments?
I am intending to replace my shock absorbers with Koni Red's and would like to make any other useful improvements at the same time. Since I drive on a lot of frost heaved and cracked roads I don't want to increase the harshness of the suspension too much.
I am personally more interested in improving the 'road feel' and 'steering feedback' than providing ultimate cornering ability. I have a wagon but have recently driven several Golf's and have the impression that Golf steering is somewhat less foggy than the wagon. I am wondering if this might be related to the greater weight and inertia of the wagon causing additional compression in the LCA bushings and top strut mount.
On the other hand I have also noted that the wagon steering becomes a bit more precise and the car seems to track better when there is a load in the rear. Perhaps the improvement is related to the change in suspension geometry as the rear springs are compressed? If this is the case then perhaps raising the front ride height slightly might be beneficial. I saw a comment somewhere that somebody had improved steering feedback by putting VR6 spacers in the front suspension. Any comments?
