kosracing
hi there i just bought someone elses misery its a 2001 tdi golf. the turbo failed the engine ran away. old owner had vw replace turbo, since then it has never been over 1900rpm. He from suggestions from others proceeded to replace the following,new injectors, new injection pump, fuel+air filter, fuel lines timing belt, timing dealer done, (it really gets good now) removed engine rebuilt complete engine new pistons/rings complete new cyl.head block machined. well... after spending all that still only revs to 1900rpm. I went to look at it and bought it for all the new parts but, am kind of curious about what is wrong. i have not got the car home yet but some quick checks i did while looking at the car. hard start cold (maybe glow plugs) engine indeed only revs to 1900rpm (seems likeitsgoverned removed intake hose off intake rpm jumped to 2100rpm... I did feel some boost from hose while reving engine. it almost sounds constipated. Also vw removed exhaust and tryed running with no luck. It shows codes did not have a scan tool handy. also un plugged mass air flow sensor no change and saw no bubbles in return fuel line, is not bad fuel old owner drove 1000kms with this exisiting problem..
had a couple ideas;
snow screen plugged
exhaust plugged (dont trust dealers)
waste gate issue
tps problem
has anyone come across something like this before or if you have any ideas please let me know
thanks
had a couple ideas;
snow screen plugged
waste gate issue
tps problem
thanks
