I have a 1998 TDI 1.9
I've check the relay wiring everything is good there. I then went to the temp sensor and check for the references volts coming from ECM and I'm getting 4.98 volt. When I unplug the temp sensor everything works. The glow plugs stay on for max. Time. What is going on?
Thank You for any and all help........
